Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Portable, and Mobile Devices
Thread Tools Display Modes
Old 05-01-2019, 03:54 AM   #1
Johndill
City & State: NSW
My Country: Australia
I'm a: Knowledge Seeker
Default Alienware 18 LA-9332P 3V, 5V short
Hi, as far as I can tell, this board has a short on 3VALW and 5VALW and I am currently stuck on what to do next.
PU100 gets hot when the AC adapter is connected so I assume it's shorted so I have removed it for testing.
QZ1 is grounded on pins 1, 2, 3, 5, 6, 7, 8.
PQ104 pin 5 grounds the DC jack shorting the AC adapter so I have removed it.
PL102 is grounded on pin 1.
PL101 is grounded on pin 1.
PL501, PL502, PL503 and PL504 are grounded when the CPU is in, they are ungrounded when the CPU is removed.
PL201 is grounded.
QZ3 is grounded on pins 1, 2, 3, 5, 6, 7, 8.
PQ201 is shorting the DC jack also and is removed for testing other stuff.
As far as I can tell, 3VALW and 5VALW are shorted somehow and I have come to an end on where to go next so I;m acking the experts on what could be going on. Thanks :-)
Johndill is offline   Reply With Quote
Old 05-01-2019, 05:14 AM   #2
piernov
Moderator
City & State: Valbonne, 06
My Country: France
Default Re: Alienware 18 LA-9332P 3V, 5V short
It's not always safe to remove a buck controller and power on the board because then the gates of the high-side MOSFET are floating, and they could pass current, meaning sending 19V to the 3V or 5V rail. If you need to power on the board with the buck controller removed, either disconnect the PJP jumper, remove the output inductor or remove the high side MOSFET.
Ignore PL501, PL502, PL503 and PL504, it's normal to have low resistance to ground there with CPU inside the socket.
You have several places shorted to ground that should not be shorted together and are mostly unrelated. I'm not sure what happened but this doesn't look good.
It's especially concerning to have PQ201 shorted but for now ignore that circuit as the 3V/5V circuit must be fixed first.
You should try to isolate the shorts as much as possible, so remove QZ1 and QZ3 (which are probably dead anyway) and check which side is shorted for both.
Disconnect PJP100, PJP101 and PJP102 and check which sides are shorted too. If they cannot be disconnected, remove PL101 and PL102.
Also check for a short to ground on pin 3 and pin 13 of PU100.
__________________
OpenBoardview http://openboardview.org | IRC #[email protected]
piernov is online now   Reply With Quote
Old 05-01-2019, 08:25 AM   #3
Johndill
City & State: NSW
I've replaced everything I removed except PL101 and PL102 as I removed them to isolate the short earlier.
QZ1 removed:
pins 1, 2, 3, 5, 6, 7, 8 shorted, pin 4 good.
QZ3 removed:
PL101 already removed:
pin 1 short
pin 2 good
PL102 already removed:
pin 1 short
pin 2 short
PU100:
pin 3 good
pin 13 good
found pin 12 short
cap PC117 short to ground, short was gone when I removed PU100 earlier.
Old 05-01-2019, 08:30 AM   #4
Johndill
City & State: NSW
Please refresh as I have corrected some mistakes ^^^
Old 05-05-2019, 05:10 PM   #5
Johndill
City & State: NSW
What should I try next?
Old 05-06-2019, 09:51 PM   #6
Johndill
City & State: NSW
Bump.
Old 05-09-2019, 01:54 AM   #7
Johndill
City & State: NSW
I'm not sure what else to test from here, suggestions?
Old 05-14-2019, 05:48 PM   #8
Johndill
City & State: NSW
Am I alone? It's so cold in here.
Old 05-14-2019, 11:15 PM   #9
ktmmotocross
Boardkiller
ktmmotocross's Avatar
City & State: slovakia
My Country: slovakia
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
to be sure u mean short is resistance under 2ohms?
to locate short remove all components where u find shortted pins
ktmmotocross is online now   Reply With Quote
Old 05-15-2019, 09:53 PM   #10
Johndill
City & State: NSW
Yes, short is under 2 ohms and continuity to ground.
That has been done in the previous posts but have still been unable to find the main short.
Old 05-16-2019, 11:51 AM   #11
ktmmotocross
Boardkiller
there are too many shorts. did u remove pu100 and check?
Old 05-16-2019, 12:45 PM   #12
khaahk
khaahk's Avatar
City & State: Tallinn
My Country: Estonia
Use lab PSU to find shorts in +3VALW and +3VS, the same with +5VALW and +5VS rails. It is most likely not an easy job - probably need to replace many components (maybe too many). If successful then replace PU100 and PU200, measure mosfets - change if needed, check ram chip for short.
khaahk is offline   Reply With Quote
Old 05-16-2019, 04:45 PM   #13
Johndill
City & State: NSW
Yes, PU100 was removed in post#1, however the shorts remained.
Quote:
I have been looking for a donor board for parts but from what both of you are saying, mine will be better off being the donor board instead, if I can find another AW 18 board to repair.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
