Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools Display Modes
Old 06-11-2019, 04:35 AM   #1
rattlesnake
City & State: Buenos Aires
My Country: Argentina
I'm a: Knowledge Seeker
Question LG 23EA53 black screen after one second, it works after 5 minutes, high pitched sound
Hello people,
When I turn the monitor on I can see the image for a second, then the screen becomes all black.
If I let it sit there and wait about 5 minutes, then I turn it off and back on again, it works normally.
But there's a hissing sound all the time, very high pitched sound.
I've been using this monitor for about 5 years.
Due to all these signs I think this is a bad capacitor.
I attach pictures of the PCB with the capacitors so you can judge and advice me what to do. Does any capacitor look bulged? Only (and slightly) the 100v 33uF one.
Any help will be appreciated!
All the capacitors I've been able to identify:
1:
2DQJ
33
100
2:
3A
VZH
68
35V
3,4:
3A
100
16J
rattlesnake is offline   Reply With Quote
Old 06-17-2019, 04:09 PM   #2
frica
City & State: Mérida
My Country: Spain
Default Re: LG 23EA53 black screen after one second, it works after 5 minutes, high pitched s
I am in agree with you that the capacitor of 100v is slighly bulged. But remember that often capacitors could be bad with no visible evidence (bad capacitance or ESR).
frica is offline   Reply With Quote
Old 06-17-2019, 04:49 PM   #3
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
The 33µf 100v, is the main filter for the led string voltage. It is likely bad, those little caps don't have much inside to make much of a bulge
R_J is offline   Reply With Quote
Old 07-10-2019, 01:00 AM   #4
rattlesnake
Question Re: LG 23EA53 black screen after one second, it works after 5 minutes, high pitched s
I replaced the 100v capacitor with a new one (it took a while to arrive).
It didn't make a difference. Actually, I ended up removing all caps to check them and all were in spec.
Put them back on, nothing changed except now I don't get the screen working for a single second.
There's this hissing noise, pretty intense.
I removed all caps and turned it on, the noise is still there.
I recorded it and amplified it, it's here:
https://vocaroo.com/i/s0J6krASxfBM
It has some kind of pulse/rhythm to it.
I really wonder where could it come from, what could cause it. What could be broken?
Could one of these components be the culprit? If not, what?
I attach high res pictures of the components.
I managed to identify some of them:
8839BMP-C
25008M
https://web.archive.org/web/20180826...le/APE8839.pdf
https://www.ti.com/lit/ds/symlink/drv8839.pdf
VOLTAGE REGULATOR (PROBABLY)
208022-TI-31A-P06564
NO IDEA
D478-BA262Z
MOSFET
https://cdn.datasheetspdf.com/pdf-do...conductors.pdf
W25X40CLSNIG - Flash ROM
https://pdf.datasheet.live/datasheet...5X40CLSNIG.pdf
TROQ - 14.3H007
CRISTAL
4R7
Signal transformer
https://www.digikey.dk/product-detai...4R7-ND/2777571
330
DKzC1
Probably signal transformer too.
PJ3049
BR210
Rectifier diode
Resistance
Some unidentified fuse?
I know very little about electronics, so please excuse my ignorance and any blatant error.
Further information about how to diagnose the problem would be very welcome.
Thank you for your help to get this monitor working again!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
