I bought at the flea market a Sony car minidisc deck and while it is a little worn it almost works perfectly. I say almost because the only thing that does not work is the AM/FM radio. I can test and get a good signal using my antenna from my old CD deck, unplug and connect it to the new deck and all frequencies are dead static. Opening it up I found the traces to the TUX-020 tuner module from the antenna connector were fine so I suspect the module itself is faulty (at least, I hope..). No worries there as my old CD deck uses the same one.
The bigger problem I noticed was that on the exact opposite of the board was this little bugger.
Nothing in the surrounding area showed sign of damage but what on earth blew it up?
