I was given these speakers, which have long-travel woofers and give amazing sound BUT the volume potentiometer is shot.
I researched this on a Klipsch board, and the volume pot problem is universal.
The volume pot is marked B503 and B50K.
I found such a dual potentiometer on Mouser. I am assuming that RV122F-20-15F-B50K is the correct replacement. This is a linear rather than an audio pot.
Since I have to dismantle the two-level board anyway, I'd like to replace the caps as well.
They are 470uf 35v Orient brand (2 pieces) 10mm. Note the burned glue at the base, and the top part of the sleeve is missing on one. They are 85C and are right beside a heatsink(!)
Next are 3 pieces 47uf 63v Capxcon 8mm 105C KM series caps
There are 2 pieces 220uf 16v 8mm Orient beside the volume pot.
There are 3 pieces 100uf 16v 6mm between the two boards.
The Orients have no series ID and I assume they are GP.
Can someone suggest suitable replacements and an opinion on the potentiometer replacement? Please see the attachments for more detail.
