Ebay DPS Power supply module current draw?
    Good day folks. Some of you may know that a while back I got myself one of those power supply modules you see on banggood, aliexpress and just about any other online shopping website. I powered the thing off a UPS transformer and I'm very pleased with the results...built a nice oversized enclosure for it and it's running quite happily. Today I wanted to test its limits a bit, to see what it can put out, so I took a wrench and shorted the output terminals together and raised the voltage to 1v. It went into constant current mode immediately, since even at 1v it would've exceeded the maximum 15A it's designed to carry - after all, the resistance of the wrench was extremely low, it's a solid piece of steel (or whatever it's made out of ). The display showed 15A indeed, at about half volt, so roughly 6-7w total.
    This is when I noticed something strange: I took my clamp meter and wrapped it around one of the wires coming from the bridge rectifier into the input of the PSU module and it only showed 3A, even though the display said 15...:| What is going on ? Is this a SMPS and the input current doesn't match the load current, or am I completely oblivious to something ? I'm pretty sure there's no way you can draw 15a on one side and only 3a on the other.....or is there ? I think we're talking about a SMPS...what do you guys think ?
    Wattevah...
    Re: Ebay DPS Power supply module current draw?
    So what is the DCV at the output of the bridge rectifier feeding the module? 2 ~3V?
      It's 48v from the transformer.
      Wattevah...
        So the total load is drawing 3A from 48V power supply, 3A at 48V = 144W of power and you are dissipating 6 ~ 7 W on the load connected to the module, that is lots of losses. The meter on the module is showing the current on the load side.
          you have heat and the fan drawing power too.
            Yes, but why is the current draw so low on the diode side and maxed on the output side ? Shouldn't it be the roughly the same ?
            Wattevah...
              You have input/output conversion so the current on the load side that is being measured will not be the same as the input side.
                yes, voltage is converted to current - or the other way around - depending on if it's a buck or a boost design.
                example:
                you say it's 48v input.
                assuming no losses (bullshit) if your output is 12v then your current increases x4
                  I reckon it's a buck converter configuration, since it converts a high input voltage to a low one and cannot exceed the input, so it's not a booster.
                  What about linear PSUs ? X amps drawn on the output would mean the same (if not slightly higher) draw on the diode side too ?
                  Wattevah...
