I have a ToteVision 18" that I got from eBay a while ago. I received it with a note that the previous owner had changed the top two lamps and still the monitor was shutting down the backlights. I opened up and saw the previous owner's work with silicone to adapt generic lamps to the rail of the ToteVision. I removed them and I couldn't turn them on (the original pair, bottom) with any other inverter but their original one (that was failing).
I ended up removing both pairs, inserting 2 rails of 17" tubes from a dead Samsung (my first attempt to repair a monitor ...) and I managed to adapt an inverter from a VE500 (FrankenMonitor? ) but it only has two lamp outputs, so I made some soldering and taping and "It's alive ....!!!!". Even the bright control worked, so I reassembled it and it was working until the last week, when I replaced it with a Polaroid 19" TLA-01911C and decided to recheck it.
The original inverter is an FSP. One output works but the other one does not, and the whole thing shuts down. I replaced a fuse (taken out previously for another monitor), changed two caps (16v 470uf. I can't remember the original series, but I do remember that they were not bulging but they were on the "Bad Boys List", so I guess it is OK - Teapo) for ELNAs to test, and connected the lamps.
Same behavior. I checked almost all the resistances on both sides, and they are the same. I found 4 transistors (Q1A,Q1B,Q2a,Q2B, being B the "Good side" and A the "Bad Side") that have C5706 2E on them. I found that they might be this component : http://www.alldatasheet.com/view.jsp...=C5906&q=C5906
When I turn on the monitor, the good side turns on, and 12v reach the cap + pole, and on the input of the L1B Inductor there a 8.4v and on the L1A only 2.34v. It is so short the time to test before it shuts down that I have not tested a lot.
Any Idea where to start?
