I was given a broken paper shredder which I was reluctant to discard since it seems so wasteful, and so I am trying to repair it.
It has a sliding Panel Switch for rev/off/auto (see image P2-Shredder-Extrnl). The shredder's symptoms are as follows: (1) The rev works; (2) Auto does NOT work as the shredder will not come on when paper is placed into the paper slot; (3) The Panel "Ready" Light also does NOT illuminate at any time.
I opened the case, and the shredder consists of: (1) Motor/Shredder Blades, (2) Mechanical Safety Switch, (3) Transformer, (4) Panel Switch, (5) Panel "Ready" Light, (6) Optical Paper Sensor, and (7) Main Circuit Board.
Since the shredder motor works in rev, I am presuming the motor and transformer are good. I checked the Mechanical Safety Switch, and that is good. I cleaned the Optical Paper Sensor thinking this might be the problem, but that did not seem to help. The 2 relays SRU-S-112L are for the forward and backwards drive of the shredder motor.
I looked at the Main Circuit Board, and noticed there was discoloration/burn marks on the board in the area of ZD1 (Zener Diode 1, at bottom of images P0-MainBoard-Frnt and P1-MainBoard-Rvrs). ZD1 is rated at 18V/0.5W, as marked on the circuit board. The adjacent resistor also appears to be discolored, but tests correctly at 300 ohms. The fuse is good.
So I am presuming the ZD1 Zener Diode provides the current for auto(forward) shredding and also power for the Panel "Ready" Light. With ZD1 presumably having overheated and gone bad, I am thinking this would explain the non-illumination of the Panel "Ready" Light and why the shredder does not work for auto(forward).
There is another Zener Diode on the circuit board which rated for 6V (located between resistors R16 and R17), which I am presuming is for the rev circuit which works.
So my plan is to replace the ZD1 (18V/0.5W) Zener Diode. However, I am posting here because I had several questions, that hopefully someone more knowledgeable may be able to assist me with:
(1) Is there a way to test the Zener Diode out of circuit, or should I just replace it since it has discoloration/burn marks? Should I also replace the adjacent discolored resistor, even though it still tests correctly?
(2) Assuming that the ZD1 overheated, would you consider replacing ZD1 with an 18V/1W Zener Diode instead of the recommended 18V/0.5W?
(3) Does my repair plan sound reasonable and explain the shredder's symptoms, or would you recommend any additional testing such as testing the voltage regulator L7812CV which is also adjacent to the discolored/burned ZD1?
(4) What might have caused ZD1 to overheat...trying to shred too many papers with motor requiring too much current draw?
(5) Any other suggestions?
Thanks very much for your suggestions and help with my repair questions.
