My HPE 5900AF-48G-4XG-2QSFP+ switch can have two types of fans (excluding normal and high performance):
Ones that blow the air from port to power, ones that blow the air from power to port.
I have two of the high performance JG552A port-to-power fans. The ones I want are JG553A, which blow from power-to-port.
The physical brushless fans inside are the exact same, but the wiring is switched around a bit. So I flipped the fans around and switched the wiring so it matched the JG553A's, and sure enough, now the fans blow the way I want, from power to port.
However, there appears to be some place on the circuit board for these fans that store the information on how the fans are supposed to blow, and I'm constantly getting an error message saying something along the lines:
I display the fan configuration, and sure enough, it does show that I have them set to power-to-port, but they're preferred direction is port-to-power.
I was going to upload some pictures of the circuit board to see if anyone saw a chip that might contain the data, where I could just switch it around. A kinda cheap hack. Has anyone ever done anything like this before?
I couldn't find any mods on the net. The proper fans will cost me over 600$, so it'd be nice if I could save that money and just change something on an eeprom or something.
Thanks.
Code:
DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 1 airflow direction is not preferred on slot 1, please check it. DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 2 airflow direction is not preferred on slot 1, please check it.
Thanks.
