This board is not outputting 13V. 5V is ok. I haven't done a lot with power supplies yet, other than replacing caps. I tested the transformer before removing it from the board with a ring tester, and the primary side was showing a short. After removing it from the board it tested good. So I think there is something shorted on the primary side. Test around and can't find anything.
I happen to have a replacement transformer that was working in another board, so I try it. Before I removed transformer B from board B, it rang good. So I begin soldering transformer B to board A. Still trying to locate the problem, I solder 1 pin at a time, and check the ring tester to see where the short is introduced. When I solder the third pin from the left on the secondary side (see diagram) then the ring tester shows short. I have all the other pins soldered in and no short, but when I solder that last pin it shorts out (ring tester shows no lights).
This seems really strange to me because the two center pins feed the 5V which is working... And even without that pin soldered the 5V still works. The only difference is I am getting a little less than 1 V on the 13V pin, where I was getting 0 before.
Any ideas?
Any ideas?
