Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Old 02-06-2017, 06:20 PM   #1281
RJARRRPCGP
City & State: North Springfield, Vermont
Line Voltage: 118-127V 59-63.5 Hz-> actualizo: pérdido de voltaje
Default Re: the gutless, bloated, and fried power supply hall of shame
Originally Posted by jazzie366 View Post
Where did you find this!? That's a KenTek PSU which the manufacturer of is currently unknown, they should be found and shamed and also made liable for all the PCs that have been destroyed by them.
That PSU looks like a laptop PSU on steroids! LOL!
MSI B450 Tomahawk
Ryzen 7 "Matisse" 3700X
16 GB Corsair Vengeance LPX DDR4 SDRAM
XFX Radeon RX 580 8 GB
eVGA Supernova G3 750W
Received on November 4, 2019:
MSI GF63 Thin 9SC-649US
"Don't eat yellow snow!" -Salem
RJARRRPCGP is offline   Reply With Quote
Old 03-16-2017, 07:40 AM   #1282
Bungz
City & State: UK
My Country: UK
Found this little beauty in a Compaq Presario A64.
Must have been a thoughtless replacement at some point for the original!
Fan was very stiff so I guess it ran hot and somewhat overloaded for some time in order to cook more or less every cap in the unit!
Bungz is offline   Reply With Quote
Old 03-16-2017, 10:17 AM   #1283
Dan81
SNES-powered
Dan81's Avatar
City & State: Romania
My Country: Bacau
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
That might actually be worth a fix.
What did they smoke to label a ERL35 transformer EI-33ASG?
Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Dan81 is offline   Reply With Quote
Old 03-16-2017, 03:42 PM   #1284
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
I think I saw a March, 2001 date code on one of the caps. There's a good chance to original PSU was from Delta, and if it lasted for 15 years, it did pretty good. At any rate, while I wouldn't use that thing for the full rated 300W when brand new, restored it would probably be good for 200W-250W. The two potential limiting factors would be the 2A +5VSB and, more importantly, the 10A rating for the +12V output.
PeteS in CA
Where might is right
There is no right.
- Sophocles in "Antigone"
All that is gold does not glitter,
Not all those who wander are lost;
- J.R.R. Tolkien, The Fellowship of the Ring
PeteS in CA is offline   Reply With Quote
Old 03-16-2017, 04:13 PM   #1285
Bungz
City & State: UK
My Country: UK
The PSU predates the Compaq by some years without a doubt.
I figured the person I acquired the machine off did a quick fix and swapped the PSU out for one from a older machine.
Usually I am up for repairing such things but the weak 12V rail really means its rather useless for me in this system.
Machine however is now sporting a 300W FSP unit and it working perefctly
Old 03-16-2017, 11:00 PM   #1286
Dan81
SNES-powered
Dan81's Avatar
My Country: Bacau
As far as my experience goes, I used recapped Deers similar to the Mercury above (except the diodes-on-bracket were replaced with actual rectifiers) to power Northwood based PCs. (in fact,one of the PCs I gave runs a P4 2.8 Northwood with a FX5200,a MSI 845E Max mobo and a 120GB WDC HDD)
Old 03-20-2017, 05:40 AM   #1287
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Oh Deer!
It's one of their "2003"/"2005" chip-of-the-year BTX designs (BTX for Deer/L&C typically signifies the primary is located on the same side as the receptacle plug and the secondary is same side as the fan... not the other way around like with other "normal" PSUs).
That said, with a better rectifier on the 12V rail and bigger output caps, this thing could probably provide up to 14 Amps on the 12V rail, which should be enough to power a Pentium 4 / Core 2 Duo / low power Core i3 or i5 system with on-board or low-power GPU and single HDD. I'm not sure if it's worth the hassle fixing it, though.
I would do it for fun, but I don't expect anyone else to be like me.
Old 03-23-2017, 02:54 PM   #1288
kevin!
recapping PCB.
kevin!'s Avatar
City & State: Gerona
My Country: España
Line Voltage: 230VAC 49Hz, 2 Ph
The worst trash I could find, this PSU i was installed on a pc, the owner of the pc complained that it did not start all the time, and it squeaked, and it did not work stable the pc.
Subject: 3G0 "450W"
primary
ate 7n60
c5027s
2 cap jay'long 200v 470 microfarads
ic ka3842
diode bridge diferent size LOL
x2 sep 1n5
x2 sep rl2
secondary
diode lt 338
switch st stps30 45cw 30A (The only thing of decent brand xD) but the transformer that accompanies ... this would cause havoc. does not meet what promises in its label.
apd sbr1040ct
4x chengx 10v 2200 microfarads
2x chengx 16v 470 microfarads for 5vsb
At least it has one good thing, it has 2 thermistors
The transformer is super tiny!
Gaming pc:
Gigabyte RX 580, Corsair RM750I.
Server:
PSU Corsair TX650M
HTPC:
Dell Alienware aurora r3
GTX 760, PSU Dell 875w.
kevin! is offline   Reply With Quote
Old 03-23-2017, 03:26 PM   #1289
RukyCon
A Fake Rubycon
RukyCon's Avatar
City & State: Peoples Republic of California
Line Voltage: 122.5VAC 59.9Hz
It's sad how that can be passed off as a 450W PSU. [I'm guessing 100W maybe.]
I like the brand of the input capacitors. [jay'long]
RukyCon is offline   Reply With Quote
Old 03-23-2017, 03:35 PM   #1290
kevin!
recapping PCB.
kevin!'s Avatar
My Country: España
It will surely be 100W, As it requires power, it bursts xD
What is not as it has not yet exploded, nor the capacitors "jay long" xD.
Old 03-23-2017, 04:27 PM   #1291
RukyCon
A Fake Rubycon
RukyCon's Avatar
What are you planing on doing to that PSU? Scrap it? Burn it? Throw it off an cliff?
Old 03-23-2017, 04:32 PM   #1292
kevin!
recapping PCB.
kevin!'s Avatar
My Country: España
I have thought, is to charge to burst, but for lack of machinery I can not do it .
I'll think of something like busting her xD.
Old 03-23-2017, 04:41 PM   #1293
RukyCon
A Fake Rubycon
RukyCon's Avatar
I have a crap PSU which i'm thinking of putting 2.1KV into the input via an MOT. [Microwave oven transformer.]
I'm not a professional, but i'll try to do the best i can, and if i'm doing something wrong, please tell me.
Old 03-23-2017, 11:14 PM   #1294
ChaosLegionnaire
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
woe... kilovolts... better be careful when u do that! u get zapped, its your funeral!
ChaosLegionnaire is offline   Reply With Quote
Old 03-24-2017, 12:02 AM   #1295
RukyCon
A Fake Rubycon
RukyCon's Avatar
Yes, i know...
I've done this more then once.
Old 03-24-2017, 02:20 PM   #1296
PeteS in CA
Actually, unless it's counterfeit, that KA3842 is either Samsung or Fairchild (Fairchild bought some of Samsung's linear IC products around that time).
Those input caps (ignoring the non-brand brand) and the size of those heatsinks would put the realistic output power at around 250W maximum.
Old 03-24-2017, 02:33 PM   #1297
kevin!
recapping PCB.
kevin!'s Avatar
My Country: España
I dare not touch a microwave transformer xD. What I want is petarla the 450w indicated, I will put several H4 light bulbs, to see if I can overload it.
I also think it, I think it is false.
Old 03-24-2017, 02:54 PM   #1298
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
That transformer is just... Wow!
PeteS in CA: Good guess, here is a user that tested it.
The primary exploded at 277w
http://www.jonnyguru.com/forums/showthread.php?t=6714
EDIT: Here it is with a 250w rating even
http://www.powsun.itxpower.net/pcpower_8867.htm
Per Hansson is online now   Reply With Quote
Old 03-24-2017, 03:34 PM   #1299
kevin!
recapping PCB.
kevin!'s Avatar
My Country: España
Thanks for this information, make it clear that it is the worst psu I have ever seen.
I even put it at less level than deer xD.
If the psu of the forum of jonnyguru exploded with 277, I do not want to imagine my PSU, since with a pentium 4 of 65w of consume gave error to start, I do not want to imagine asking for load of 277 watts, there it explodes in my face.
Old 03-24-2017, 10:07 PM   #1300
RJARRRPCGP
In most of the Americas, you would be lucky to get 150 W out of it...
Badcaps.net Technical Forums © 2003 - 2020
