Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 06-15-2018, 01:38 PM   #1
coreAngel
coreAngel's Avatar
City & State: FL
My Country: United States
Line Voltage: 120 VAC 60Hz
Default Help with LG DVD player recap
Hello everyone need some help with an LG DVD player.Bought it last year and the caps in the primary power supply area have not bulged but capacitance is definitely not in spec, the ones in the decoder board are all bulged.
The power supply board has a mix of Jicon and ZHN caps?
I was thinking of replacing the caps with IC (illinois capacitor) or Vishay caps not willing to spend much but mostly as a project to practice recapping.
I can use general purpose caps in the power supply? and low esr/low impedance in the decoder board?
Thanks for your help
Yes i love Nichicon MUSE Audio Capacitors...they would look awesome all over any motherboard
coreAngel is offline   Reply With Quote
Old 06-15-2018, 04:12 PM   #2
kaboom
"Oh, Grouchy!"
kaboom's Avatar
City & State: PA
Default Re: Help with LG DVD player recap
Garbage! As Shango066 would say, chineezium caps... Amazing you got a whole year out of it, those are junk/leaky/out of spec within 6 months.
Nichicon VZ, CS, PW, PS, HE or Panasonic FC, FR, NHG for the bulk cap after the line rectifier. Not all of those series are available in 200V.
For other power supply caps: Nichicon PW or HE, or Panasonic FC or FR.
ASSuming the decoder is thru hole, try Chemicon KYB for smaller can sizes in addition to PW, HE, FC, FR. Any nonpolar electros can be replaced with Nichicon EP. Panasonic has equivalents, but I use so few nonpolars that I've never needed to look them up.
The only IC caps which are true-to-heritage are the large can, screw terminal ones. If you look at any of their small electros, you'll see the "circle-R" trademark thing just beside the IC logo. Someone else makes those for IC; they aren't the Illinois Capacitor of the 80's and 90's. From my research, they're overpriced at best, dubious at worst in high temp cramped electronics. Not a fan of Vishay electros- too much under the "umbrella" if will...
"pokemon go... to hell!"
EOL it...
Originally Posted by smashstuff30
guilty,guilty,guilty,guilty!
guilty of being cheap-made!
kaboom is online now   Reply With Quote
Old 06-15-2018, 05:16 PM   #3
coreAngel
coreAngel's Avatar
City & State: FL
Thanks for the response
I spent about 19 dollars on this unit, and even though its under warranty cause the caps look ok but the player has problems, it costs almost as much as the unit to send it and get a "refurbished" one back
I asked about IC cause they are cheap i mean like less than 10-15 cents a piece, there are Lelon (Lecraps as i call them) and the are like one to 3 cents a piece... the ones i might prob go with is Kemet or United Chemicon, the pannys and nichicons are expensive over a dollar each for some of them.But i didnt really want to spend too much as i just plan to use it for practice on replacing caps.
I haven't heard anything bad about Vishay, i dont know how they are quality wise.
Old 06-15-2018, 06:40 PM   #4
kaboom
"Oh, Grouchy!"
kaboom's Avatar
City & State: PA
Vishay ceramics and MLCCs are OK, I just never use the 'lytics...
If this is just for practice/experience and you're not interested in the repair lasting 10-15 years, you can even "substitute" general purpose caps for everything, if they're excellent quality.
Relatively speaking, I've put Nichicon VRs in similar power supplies when waiting for "correct" replacements to arrive. Yes, VRs are even better than some of the junk I've seen. Samsung VCRs used similar trash capacitors- I was usually able to bring up the power supply even with half the output section recapped with Nichicon VRs.
The rest of said VCRs were another story. Not just dirty mode switches, but they had a run of bad micros where the bonding wires broke inside the IC- made for strange issues. Every one of those got junked- they'd be OK anywhere from a week to a month of evening use, but just when you thought it was safe to give back, the micro would run the loading motor to the mechanical limit and jam everything. Was not the mode switch, but deck/servo control ckts inside that big IC. The inputs from the mode switch were ignored. Not bad soldering either- those things were absolute pigs.
Fun times, but I digress...
Old 06-15-2018, 10:26 PM   #5
coreAngel
coreAngel's Avatar
City & State: FL
Most of the DVD players i have one is LG like i asked here, the other one is Sony with Taicon caps, all are in spec (after 5 years im surprised), the last one is Sanyo (made by Funai Corp) All Lelon c(r)aps ...
So ill mix some Kemet, Nichicon's whatever is at a reasonable price, ill post here what i got.
Even one of my TV Digital Analog Decoders, is using get this: Daewoo capacitors.... it was in spec, Daewoo?? wow, and Toshin Kogyo parts..
The best VCR i had that lasted 20 years from 1992 to 2012 was a (Radio Shack) Realistic VCR (assembled in taiwan) all had NCC,Sanyo,Nichicon parts.
Fun times are the best,
The worst thing i have dealt with was a jWin Radio i purchased for my grandmother, after 12 years the audio quality was poor, so i opened it, good lord i have never seen so many odd name c(r)aps in my life all leaking and eating through the board.
Names, XEN, FCARP, Benqt, Jkoe, Chengli, i dumped it after popping all the caps lol.
Old 06-16-2018, 03:59 AM   #6
stj
stj's Avatar
City & State: Europe
you need low esr caps or they will overheat - just saying.
Old 06-16-2018, 10:18 AM   #7
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
Lelon is junk. Maybe higher end, well marketed junk, but junk.
Your time is worth more than the cost of whatever caps you use, so use good caps - PW and HE from Nichicon, LXZ and KZE from UCC, etc..
PeteS in CA
Where might is right
There is no right.
- Sophocles in "Antigone"
All that is gold does not glitter,
Not all those who wander are lost;
- J.R.R. Tolkien, The Fellowship of the Ring
PeteS in CA is offline   Reply With Quote
Old 06-16-2018, 06:21 PM   #8
brethin
City & State: Owensboro, KY.
Line Voltage: 120VAC 60Hz
Part it out, it's not worth fixing.
brethin is offline   Reply With Quote
Old 06-16-2018, 08:28 PM   #9
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
^Agreed, plain old DVD players are a dime a dozen in thrift stores. for $20, if it's nothing special (not blu-ray, HD-DVD, etc.) you legitimately were ripped off. Hell I scored an LG "smart" blu-ray player for $20 not too long ago... certainly loads faster than my ancient Sony unit (which was an early blu-ray model, slow as dog shit). Even if it has a VCR combined (minus one exception), those too are easy to come by, at least around here.
Now if it was a DVD player/S-VHS combo unit (extremely rare), then it would be worth it; I did actually find one once and the PSU inside needed recapped badly... so I did go through the trouble.
Fix things that are actually worth fixing. Time is too valuable to bother with things that are easily and cheaply replaced, unless you have a very specific reason to go there (learning, etc.).
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 06-16-2018, 08:34 PM   #10
coreAngel
coreAngel's Avatar
City & State: FL
Well its like i've mentioned before, its more of learning with soldering and de-soldering caps than anything, not really interested in the LG DVD player, the Sony one is ok. The Sanyo was like 10-11 bucks brand new and has play from USB thing, and still works, the worst is the LG one.
Old 06-19-2018, 03:31 PM   #11
coreAngel
coreAngel's Avatar
City & State: FL
These are the caps i've selected to use as replacements
Power Supply Board
General Purpose Caps
https://www.mouser.com/ProductDetail/667-ECA-2EM220
https://www.mouser.com/ProductDetail/80-ESK108M016AH2AA
https://www.mouser.com/ProductDetail/710-860020374012
https://www.mouser.com/ProductDetail/710-860240672002
Main Board
Low Impedance Caps
https://www.mouser.com/ProductDetail/647-UPS1C101MED
https://www.mouser.com/ProductDetail/647-UPJ1C470MDD
https://www.mouser.com/ProductDetail/647-UPJ1C221MPD
https://www.mouser.com/ProductDetail/647-UPW1C100MDD1TD
Any suggestions? Thanks
Old 06-20-2018, 01:36 PM   #12
coreAngel
coreAngel's Avatar
City & State: FL
Any suggestions?
Old 06-20-2018, 07:00 PM   #13
coreAngel
coreAngel's Avatar
City & State: FL
Can a mod close this post since its gone inactive
Old 06-21-2018, 07:06 AM   #14
Andrew F. Ali
Andrew F. Ali's Avatar
City & State: Point Fortin
My Country: Trinidad & Tobago
Line Voltage: 125VAC 60Hz
Sometimes when I get something to repair, I consider the cost of my valuable time, electricity bill, etc and if it isn't worth it as my service charge might very well be more than the cost of a new unit, I return it to the Customer-No Charge. Of course I explain this to them and let them leave with their junk as I have enough junk of my own.
Andrew F. Ali is offline   Reply With Quote
Old 06-21-2018, 08:17 AM   #15
coreAngel
coreAngel's Avatar
City & State: FL
Oh yes im well aware of the time, and it may be junk, but im using it really as soldering practice and repairing stuff, plus it gives me an excuse to buy caps.
Old 06-21-2018, 10:56 AM   #16
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
The list of low-impedance caps looks good to me. You have Nichicon PS, PJ, and PW. Those are all fine for PSU use.
As for the general-purpose caps list, I suggest staying away from Kemet and Wurth electrolytic capacitors. I don't know if they are bad (well, in all honesty, they probably are still much better than no-name Chinese garbage craps), but I don't know how "good" they are either... or particularly how long they would last.
Like you, I often find myself looking for the cheapest caps to buy on Mouser and Digikey when repairing something "not-really-worth-the-time-but-fun". What I've found, though, is that there is almost no reason to ever buy GP caps, because some entry-level low-ESR caps can be just as cheap, if not cheaper than GP caps.
That said, here is a list of low-ESR caps I regularly use in PSUs:
Panasonic: FC, FK, FR, FM, FS
Rubycon: YXA, YXJ, YXG, ZL, ZLH
Nichicon: PS, PJ, PM, PW, PA, PV, and HE
Chemicon: KMY, KY, KYB, LXV, LXY, LXZ
In particular, I find that Rubycon YXJ and ZLH, as well as Nichicon PS, PJ, PM, and PW are usually the cheapest caps to buy.
But if you don't mind GP caps, there's always these:
Panasonic: M, EB, EC(A)
Rubycon: AX, PX
Nichicon: VR, VZ, VY
Chemicon: KMG, KMQ, KMY
In the end, though, I don't really think it's worth going ultra-cheap and getting GP caps where you should have low-ESR ones. The difference, for something like your DVD player might be $1-3 at most. To me, that's not too much of a difference when you consider that quality caps will outlast the useful life of the device (and when they do, you can pull them out and re-use them in something else).
Old 06-21-2018, 11:12 AM   #17
Andrew F. Ali
If you want soldering practice and really want to learn about how different parts/components work and there use/purpose in electronics you could probably get some building projects. This way once you understand the basic principles troubleshooting would be easier.
Old 06-21-2018, 11:21 AM   #18
momaka
momaka's Avatar
My Country: U.S.A.
ASSuming the decoder is thru hole...
Well, even if it isn't, you can always bend through-hole caps to the side and solder their leads in place of where the SMD caps had theirs.
FWIW, SMD caps are almost always overpriced relative to their through-hole counter parts, and to add injury to the insult, they typically have lower endurance ratings too.
Thus, I never buy SMD caps. However, I do re-use them - that is, if I can take them off without destroying them. Most recent and easiest method I've developed for that is: screwdriver + hammer
Works without damage almost every time. And if it's a lead-free mobo, put it in the freezer and the solder is even easier to break.
No surprise there at all. After all, many late (and not-so-late) -era Sony CRT monitors and TVs were full of these, along with Rubycon YK. Even in the hottest sections of the CRT (the CRT neck board), these would still hold up fine for at least 10 years without issues. Same goes with Panasonic CRTs filled with their own Panasonic GP (M?) caps.
And like you, I've done temporary recaps of SMPSes with those GP caps as well, and they held up fine for whatever duration I needed them to work without a hitch.
On that note... CoreAngel, if you see any busted Sony, Mitsubishi, or Panasonic CRT TVs on the side of the road, see if they still have their boards inside them. You'd get a ton of useful parts from them, including quality GP caps. Sure they may be old and possibly getting near their end of "estimated" service life, but I'm still willing to bet down a $20 they are better than Chinese/Taiwanese no-name garbage caps (and in some cases, even better than the known-garbage caps, like CapXon, for example).
LOL!
Old 06-21-2018, 04:24 PM   #19
petehall347
City & State: worcester
My Country: United Kingdom
file a claim for unfit for purpose .
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
