Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 08-03-2017, 06:44 AM   #21
Wayno
City & State: Durban
My Country: South Africa
Default Re: Which Metallized Polypropylene Film Capacitor Should i use ?
I would just like to see that they looked like completed,instead of the yellow caps.
Don't stress was only asking a question.
Wayno is offline   Reply With Quote
Old 08-03-2017, 07:21 AM   #22
Wayno
Sorry all for Hijacking this thread, would this be the correct cap for the smaller of the two.
http://za.rs-online.com/web/p/polyes...itors/6225069/
I cannot see so well on my cellphone.
Old 08-03-2017, 07:32 AM   #23
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Didn't mean to come off as an asshole, sorry
I think the ones he used are these:
http://za.rs-online.com/web/p/polyes...itors/6225075/
This should also be a nice replacement, being X2 classed:
http://za.rs-online.com/web/p/polyes...itors/8740829/
http://za.rs-online.com/web/p/polyes...itors/8740826/
Old 08-03-2017, 02:36 PM   #24
Wayno
Thank you so much for your help.
Will get the better ones and try it out.
I am a real newbie to this stuff, agents and tecsa want nearly R3000 for a new PC board. If the replacement of the capacitors work like it did for RickyZa, then it saves me huge.
Old 08-03-2017, 03:06 PM   #25
Per Hansson
City & State: ----
My Country: Sweden
Be sure to order replacements for the electrolytic caps as well!
Old 08-03-2017, 04:54 PM   #26
redwire
City & State: Alberta
My Country: Canada
Default Re: Whirlpool WRF40 fridge Metallized Polypropylene Film Capacitor Replacements?
C9: 470uF 10V? electrolytic (P=?mm)
C5: 100uF ??V electrolytic (P=?mm)
C4: 1,000uF 10V electrolytic (P=?mm)
C10 - 0.47uF 250VAC metal film (P=22.5mm)
C11 - 1uF 250VAC metal film (P=22.5mm or 27.5mm)
If you can check/update the some of these numbers to help others.
I put these in from the pictures
redwire is offline   Reply With Quote
Old 08-07-2017, 06:21 AM   #27
Wayno
I am planning to take the board out tomorrow to work on replacing the Capacitors.
@ Redwire, I will update the numbers for you when I remove the capacitors, probably later tomorrow.
Old 08-16-2017, 03:09 PM   #28
RickyZA
RickyZA's Avatar
City & State: Western-Cape
My Country: South-Africa
Hey guys, i see things have been happening over here, i need to configure my notifications as i got nothing.
In anycase the Panasonic caps you posted are the exact ones i ordered Hanson, i just double checked and stock numbers are indeed the same.
Wayno did you manage to solder those new caps back on ? If not i can find the pictures i took of the finished job, they somewhere although its really simple, they bipolar ofcourse so you can mount them anyway you like.
Did you manage successfully actually getting the top cover off and getting the actual pcb out ? Thats a bit tricky.
RickyZA is offline   Reply With Quote
Old 08-16-2017, 03:16 PM   #29
RickyZA
RickyZA's Avatar
They are insane, i mean for such a simple board ... You get brand new Defy's that are the same size for R4500 these days. This should work for you especially if you have the same problem as i mentioned in the post. Let me know if you need any other help !
Old 08-22-2017, 02:34 PM   #30
Wayno
Hi RickyZA,
No I haven't had a chance been putting it off for a while, just moved house and trying to sort out chaos.
The top cover is a bit tricky and I wanted to spend more time in it so I don't break any plastic clips. Any pointers?
Old 06-13-2018, 07:53 AM   #31
Wayno
Hi Redwire,
Eventually I repaired my fridge. I changed all the caps. All is working perfectly.
Update - C5: 100uF 35V electrolytic
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
