My laptop's backlight was not turning on, so I attempted to replace the inverter. While checking the voltage and testing the fuse on the old board, one of the leads from my MM slipped and touched the fuse and pin#1 on the connector leading to the mother board.
Now after replacing the inverter, the laptop does not turn on at all. The only thing I get is the charge light when I plug in the AC adapter.
I went as far as opening the laptop and checking the F1 fuse along with several other fuses and resistors but they all checked out fine.
Anyone have any pointers? BTW, this is a HP DV1000.
Thank you in advance.
