Killer Computer Cases Research
    Re: Killer Computer Cases Research
    Originally posted by bushytails
    whatever happened to a nice beige box, rather than hideously ugly shiny things with windows and lights that light the room up and look like crap?
    --Randy
    And just what's wrong with a bit of bling?
    Personally, there are too many cases that take the 'modder look' way too far (that devil faced case for example), can't beat the straight clean lines of a CoolerMaster case IMHO
    For the record only 1 of my 6 cases are lightly modded (LED lighting & color coding) with modding to allow a 120mm intake on the front bezel, the rest are pure unadulterated beige!
    Viva LA Retro!
      What about a black Antec P180?? I know they're a bit expensive, but i've got one, and the finish is gorgeous.. I know having the PSU at the bottom of the case induces some quirks, but my Fortron Blue Storm 400W's wires were more than long enough. Right now i have 6 hdd's, two opticals in it..
        Originally posted by arneson
        I wish you had marketed that, The Maxx Cool, would have been an instant success. Great ideas that got away.
        Wasn't my idea, I actually bought my first parts from a place called Overclocker's Hideout, but had bad luck with their waterblock. Stabbed a screwdriver through my favorite Shuttle Super Socket 7 motherboard trying to mount it. So I made a waterblock at school that would fit with a normal heatsink clip I had. The radiator was also added by me.
        After all this happened, the water cooling business exploded with companies like Swiftech making complete kits. Ones that looked much nicer and worked better
          here is that satan case i posted about.
          btw it had a deer psu in it that did a meltdown.
          replace psu and recapped the mobo for the customer.
            hahaha i will get one of them for the accountant.
              kc8adu. never. post. that. again. My eyes have burnt out.
              The great capacitor showdown!
                Well Chris...It could be a lot worse, like this NZXT Guardian...
                There's a pretty decent chassis under all that bling, though.
                You know there's something wrong when you open up a PSU and are glad to find Teapos.
                Why I don't buy cheap cases!
                  Yeah, if I got that case, I'd rip the door off. Nice chassis design though, I've seen that case irl.
                    Everything is vertical these days. Will there ever be a horizontal ATX case?
                    Find Nedry!
                    Check the Vending machines!!
                    <----Computer says I need more beer.
                      There have been bed-type (horizontal) micro-ATX cases for a while, but they're not particularly popular or easy to work on (you generally have to place the monitor on top, which makes it hard to access the innards).
                        I see no problem.
                        I actually padlock my case anyways.
                        Find Nedry!
                          i have several aopen desktop atx cases here.
                          not real common but they are out there.
                            If I had a desktop atx case, I'd stand it on its side under my desk anyways....
                            Ludicrous gibs!
                              4u rackmount cases would make cool desktops
                                They are typically not designed to have a monitor sitting on top of them, however. They usually have rather thin top panels.
                                Ludicrous gibs!
                                  I prefer roomy towers, but I wish they would go back to using thick, heavy steel like the computers of about 15-20 years ago. I'm tired of these tin-foil POS cases with the contoured front bezels.
                                    get a chenming built case then
                                      Or a Thermaltake Xaser III......bomb proof and heavy, and even worse when filled with parts
                                      I have the Kandalf, which is pretty much the same as the Armour (I think) but it has a front door. But, this can be removed so that it just has the two 'wings' like the Armour.
                                      Tt Armor+ black case--Corsair HX1050--Intel i7 920 (default)+Noctua U12-Gigabyte GA-58EX-Extreme--6GB tri-ch. Corsair Dominator+ Corsair Dominator memory cooler--2 X Gigabyte 6870OC CF -2 x 300GB WD V-Raptors--1 X 500GB WD Green--1 x WD 250GB--1 X 1TB Samsung F3--8 case fans--Samsung T220 22" + Dell WFP2408 24"--Logitech G15 keyboard-Logitech G500 mouse--Onboard sound--plus other bits.
                                      OS-Vista-64bit+Win7-64bit+Win 8 64bit.
                                        i think you are talking about the steel version
                                          well i have a horizontal ATX case.
                                          Takes about 20 minutes to get apart though. 10 seconds to take of the top panel. 10 minutes to get the disc drive out and 9:50 minutes to get the HDD out. and if i need to get the frount bezel off. i need the HDD out so a further 15 seconds.
                                          And THAT is when i am concentrating...
                                          Stats Reset Every Month.
                                          My Forums
