Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Other Devices with Bad Capacitors
Thread Tools Display Modes
Old 08-01-2017, 07:17 PM   #1
Michael Long
Longdude
Default Refrigerator Control Board WPW10310240 Maytag Kitchenaid Amana Kenmore
Recently I had a coworkers refrigerator that stopped cooling after seven years of service.
This Control Board is located on the backside of the refrigerator. The control board part
number W10213583D replaced by WPW10310240 can be purchased for a repair service on eBay for
$80 but as we have learned in here why replace when you can repair your board yourself.
The Control Board has four 10uf 50v CAPs and I found the two 10uf 50v Capacitors off by themselves
were bad. The two 10uf CAPs side by side tested good. I would recap the entire board.
The refrigerator is now up and running for the last two months. Good Luck with your repairs.
Michael Long is offline   Reply With Quote
Old 08-14-2017, 02:25 PM   #2
OldManDan
City & State: Fort Lauderdale, Fl
My Country: usa
I'm a: Knowledge Seeker
Default Re: Refrigerator Control Board WPW10310240
I want to thank you for taking the time to post the problems with this board. My neighbor lost his Fridge last Thursday after a power outage. Being an old Car Radio Tech I told him I knew nothing about appliances. He insisted and I told him no. He called a Company to come out and they told him it would be like $400 and they actually recommended he purchase another Fridge. Unit is only 6 years old. So I started googling and found this website and your post. I am glad I did. One of the 10 microfarad's was bad and I went ahead and replaced all the caps on the board just to be safe. Unit fired right up and everyone is happy. Thanks again!
OldManDan is offline   Reply With Quote
Old 08-22-2017, 10:09 PM   #3
Michael Long
Longdude
Great to hear it.... and High Five on your repairs... I love to hear
" PAY IT FORWARD " posts like this... Keep up the good work...
Old 11-05-2017, 02:28 PM   #4
davidbennett
City & State: Melbourne, FL
My Country: United States
Just want to say THANK YOU for posting this information. We fixed our Whirlpool fridge by replacing one cap on the main board. Didn't test the caps first, just replaced the one closest to the logic board - seemed like the logical choice (LOL!). You just saved us over $1000.
davidbennett is offline   Reply With Quote
Old 11-20-2017, 04:48 PM   #5
Undertow
City & State: WI
My Country: USA
Another HUGE THANKS for this post, saved me $200 for a replacement board for a Maytag French-door fridge. I replaced the two 10uf 50V capacitors described above (off by themselves, not lined up symmetrically like the other two) and VOILA!
The board I had was marked W1032695b, replacements were W1032695 or wpw1032695 and ran from $170-200. The board looked almost identical to the W1030240 (WPW1030240) that started this thread, but they're not interchangeable. Sorry for all the extra deets, I'm hoping it'll help someone else if it gets scraped.
Undertow is offline   Reply With Quote
Old 11-25-2017, 06:59 PM   #6
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I like it when a plan comes together
Also thanks to your repairs a lot less for the land fill
and you saved a lot of money
Good work to everyone who have had to do these repairs
I have done these types of repairs on refrigerator and air conditioning defrost boards before
either because of dirty cracked soldering joint to connectors or components
Bad capacitors bad power switching power supply regulator IC chips or other problems
Now the only time I can not repair a board is if the board has a lot of burn up traces or the micro processor chip has fried or the components no longer available or the cost of parts almost as much as a new board
Here is short story about a friend of mine who air conditioning unit would not go into defrost ( this had giving problems the season before but most of time it would work)
He says to how much does it cost for a new defrost board for Trane unit they run about $350.00 for one
The problem with this defrost board that about 3/4 of main connectors pins to the board were cracked or solder was missing from the pads and to make matters worst it had bad caps ( high ESR reading ) on the board as well and more cracked joint through out the board
Replaced all the caps ( cost about $5.00 / solder Desoldiering Gun consumables $ 5.00 / time labor about 2.5 Hours = $75.00 ) resoldered all pin connectors with fresh solder and most all of components pads on this board / also the Air conditioner has some other problems besides the defrost board
This rate is a lot higher if I do not know you more like $120.00 to $150.00
After all the repair work the defrost board work good as new for $ 80.00
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 01-04-2018, 08:33 AM   #7
m3rdpwr
City & State: Boston, MA
My Country: USA
Just found this recently.
Wish I had saw this site when my fridge died I would have been up sooner.
I got prices for 115-280 for the board, but out of stock.
Went through and replaced the 4 10uf caps, only $2.
The 270's seemed like they were okay, but I replaced them anyway with some quality ones, had some Panasonic's and Nichicon 220uf on hand from when I was fixing my Neato vacuum. Why not, I had the board out anyway. (270 not common here, just 220 and 330.)
I didn't replace the 47uf or 33uf because they appeared to be out and I didn't have anything close.
Had a Weller solder station and solder wick that was I bought maybe 30 years ago. 35 watts was tough getting some out with those thick traces.
Re-solder just about everything that wasn't surface mount, although one SMT resistor near the bank of 270uf looked like a leg was detached.
I don't do nearly anything compared to what I did back in the 80's.
Funny I found the new proper cap's in the package from when I worked at RS in the 80's.
I would have used them if they weren't so old.
Around here we seem to only have just one place left, You Do It Electronics in Needham, MA.
Cost me more in gas and toll's, but in the end everything worked out.
I couldn't find a brand on any of the old cap's, just the value and 105* temp rating.
Cheap cap's in all these boards.
Edit: Got a magnifying glass, looks like a M with curved legs in a rounded square.
Mallory was the only one that came to mind, but I don't think that's it and I couldn't find the image online. Anyway.
Anyway, sorry for the ramble.
Good to have found this information here too.
m3rdpwr is offline   Reply With Quote
Old 09-23-2018, 12:32 PM   #8
Bobeng
City & State: Downers grove / il
My Country: Usa
Replacing the 4 caps 10uf @50 and the 47uf@25 should fix the issue.
Go for the low ear value caps with the higher temps since this board will be placed back in a cabinet
If time allows there is 4 other caps that could be replaced this will provide piece of mind to you. You will be saving over $200 for a control board and even higher cost for a new refrig
Bobeng is offline   Reply With Quote
Old 12-02-2018, 09:24 PM   #9
bluetoothxp
City & State: Lindenhurst
I just had an power outage. After power came back on, the fridge panel remained blank. Quick search for the board model number and I found this topic. One of the 10uF was reading 2.5uF. Replaced all four with some cheap caps from the kit I had. Fridge is back online. Big thanks.
bluetoothxp is offline   Reply With Quote
Old 05-17-2019, 10:26 PM   #10
jeffery_1965
City & State: Vancouver, wa
My Country: usa
Thanks so much for posting this. Our fridge went out today and I found this site. Just finished swapping the caps out, and it fired right back up! Woo Hoo
jeffery_1965 is offline   Reply With Quote
Old 05-22-2019, 05:11 PM   #11
Retro-Hipster
Tinkerer
Retro-Hipster's Avatar
City & State: Salt Lake City
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Quote:
Bad Ass Jeffery! And congrats! This site really is quite the staple/hangout of experienced tech. haha
I have gotten help on here more times than I can count and without even needing to post my own question. (search-fu is strong) Eventually I joined to try to give back a bit.. Anyways, Throw away culture < fix-it culture .
__________________
“Men always seem to think about their
past before they die, as though they were
frantically searching for proof that they
truly lived.”
– Jet (Cowboy Bebop) -
Retro-Hipster is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
