Toshiba Satellite A300 keep rebooting itself ?
    Dear Badcaps Members,
    I have Toshiba Satellite A300 keep rebooting itself.
    What 's wrong with it ?
    It's on, I can access BIOS, but by the time inside OS, it's rebooting,
    Could it be a bad caps ?
    Re: Toshiba Satellite A300 keep rebooting itself ?
    if there is nec token caps replaced it
      now it's completely off after I plug out and plug back in the battery....
      Any clues ?
        Yeah this one should have a NEC Tokin under the CPU so it may need to be replaced.
          What do you suggest me for replacing it ? thanks
            just replaced with 330uf 4 or 5 tantalum caps
              not tantalum, polymer.
                Aluminum polymer I guess you mean?
                  Now it's completely off,
                  And I can not turn it back on....
                  Any clues for hard resetting it ? thanks
                    I'm also with the others. Remove that NECTOKIN shit under the CPU(underside of the MB) And put 4 330uF Aluminum polymer Caps in its place.
                    What it usually looks like SEE HERE
                    What it should look like after the fix, SEE HERE
                    Good luck
                    while alive { live(toFullest=true) }
                      Good luck
                      Now it can not start at all, before it can boot, but turn on and off,
                      is it only because capacitors ?
                        what's the size of that tantalum 330uF ? what rating ? 3V ?
                          that one is good ?
                          https://www.aliexpress.com/item/10PC...b-8e8d22f8bafd
                            What's the size of that capacitor ? 7343 ?
                              Look at the links i gave you... they contain visual info of the caps... they are 330uF Capacitance and Voltage should be more than 3V at least. CPU are 0.8 - 1.4V usually depending on make.... any scrap or spare board will have them on. if you dont have 330uf then just do the math and add whatever you have to make that up...
                              Here is another image
                                that is not for NEC TOKIN if he cannot start it
                                  dont u have ATI northbridge?
                                    I'm thinking using this :
                                    https://www.aliexpress.com/item/10PC...30453c00slVmjS
                                    How do you guys reckon ?
                                      Why buy for these caps. You can easily get them from scrap mb
                                        I can not find any on my scrapped mb
