tried to reflash the bios to remove the user power on password , it is amd so i believe i just have to flash the main bios right away using the bin rom file from hp website ?? i tried that and all went good through my programmer and verified , then i went to solder the bios chip back to the motherboard when press power button laptop is dead . dpesn't turn pn at all . no lights except the power led light in the front when you get when you plug the charger . there's voltage on all bios pins except no voltage on pin 1 and 8 ??? what am i missing , please advice
help hp probook 6565b
Re: help hp probook 6565b
it is winbond chip , it was detected fine by the programmer and all went good and verified , does amd probook needs dump file or it can be flashed right away using the official bin file ?? as far as i know you can flash amd bios right away ? can someone confirm or correct me ?
Originally posted by new View Postit is winbond chip , it was detected fine by the programmer and all went good and verified , does amd probook needs dump file or it can be flashed right away using the official bin file ?? as far as i know you can flash amd bios right away ? can someone confirm or correct me ?
i need the dump file to use it with my programmer not the official one . i already tried the official one it doesn't work .. not a graphic issue . it has AMD A6 processor which it is APU ( cpu + gpu ) combined together into the processor , the laptop will not turn on at all no power the only light on it is the charger light , no respond to power button and this happened after i flashed the bios . thank you
Originally posted by new View Postanyone can provide me with the dump file , once again please don't send me the bios update file it will not work , i need the bios dump file to flash it with the programmer
