Toshiba A300 keep restarting ?
    Dear Badcaps Member,
    I have an issue with Toshiba A300 keep restarting ,
    If I don't put boot on USB , it's stable,
    but by the time I try to boot with Ubuntu 16 on USB, it's restarting all the time,
    I have put a new heat compound and change NEC tokin capacitor,
    What else missing here ?
    Re: Toshiba A300 keep restarting ?
    when does it restart exactly? at what stage of booting or in the OS?
    If it is Ubuntu, read the last message of the screen just before the restart happens.
      I'm not sure, I can not see anything on the screen,
      only empty blinking cursor I don't use keyboard at all, only boot from USB ...
      Any clues ? or experience relating with it ?
        now you should test booting from a different OS on a different USB memory.
          That's the message and it's freezed on that point,
          What's wrong with it ?
            the problem seems to be related to a MMC card. If such a card is connected to the mainboard, remove it. then try again.
            does the laptop boot normally from the hard disk if you do not use a USB memory?
              I guess it's just randomly crashing and it happened that the SD controller was being initialized this time.
              Maybe the replacement caps for the NEC Tokin aren't good enough.
                It can run now, but only one core detected,
                suppose to be 2 cores
                Is it half of the CPU failed ?
                ACPI = off on GRUB, ubuntu 16.04,
                Any clues ?
                  it really looks like bad tokin
                    I fully agree with piernov and ktmcross. I'll suggest to replace those caps again with 4X330uf caps.
                      I have replaced it with 4x330uF Tantalum Caps,
                      But only 1 CPU can run, looks like the other half is fail.
                      boot with Ubuntu 16.04 LTS
                      I have activated dual core in BIOS but it can not run ?
                      Any ideas ?
                        did u try another OS?
                          Windows 7 can not boot, Ubuntu 12 and 18, same response,
                          Fedora 29, must use noacpi=off on grub, then it can boot....
                          is it possible that half of the CPU fail ?
                            where is it notified in the Bios or in the OS that half of the CPU is not active?
                            it may give a clue to solve it.
                              It's in the OS
                              Architecture: x86_64
                              CPU op-mode(s): 32-bit, 64-bit
                              Byte Order: Little Endian
                              CPU(s): 1
                              On-line CPU(s) list: 0
                              Thread(s) per core: 1
                              Core(s) per socket: 1
                              Socket(s): 1
                              NUMA node(s): 1
                              Vendor ID: GenuineIntel
                              CPU family: 6
                              Model: 23
                              Model name: Intel(R) Core(TM)2 Duo CPU T9400 @ 2.53GHz
                              Stepping: 6
                              CPU MHz: 2527.474
                              BogoMIPS: 5054.94
                              Virtualisation: VT-x
                              L1d cache: 32K
                              L1i cache: 32K
                              L2 cache: 6144K
                              NUMA node0 CPU(s): 0
                              Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss tm pbe syscall nx lm constant_tsc arch_perfmon pebs bts rep_good nopl aperfmperf pni dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm sse4_1 lahf_lm tpr_shadow vnmi flexpriority dtherm
                              bianchi@bianchi-Satellite-A300:~$
                              I have changed on the BIOS to dual core, but still 1 core in the OS,
                              What is the issue ?
                              I'm thinking that my CPU is half dead....
                                The T9400 is 1066 MHz FSB .Does the A300 chipset only support up to 800Mhz fsb .
                                  and update bios to latest version
                                  Im Back... sort of...
                                    Depends, there are a lot of A300 models. 965 chipsets won't support this CPU (won't even boot), but 3 and 4 series will.
