I have problems with a already totally recaped PSM217-404-H-R used in HG281D, HSG1040, VX2835WM, ... Since the rest of the TFT runs fine (with another power supply), the power supply doesn't wake up from standby, there is no voltage on the secondary side (just stand by 'SB+5V'). Even if the monitor is connected to main board and power button pressed, neither standby SB+5V is direct wired to power switch on 'PSON'. Just voltage on main cap (C3 150muF/420V) drops from 320 to 318 volts. TFT reacts on power button, but the blue LED is just blinking or went off. More details:
used caps:
measured voltages:
Q501 and Q502 are dead, nothing measured there.
Would be great if anyone has an hint or idea! Thanks and regards
Paul
used caps:
Code:
Nr. [muF] [V] -------------------- C3 150 420 C203 2,2 50 C205 1,0 50 C108 10 35 C111 22 35 C114 2,2 50 C403 470 35 C406 10 50 C601 22 400 C603 22 35 C606 1,0 100 C605 47 50 C701 1000 10 C707 22 35 C301 1000 25 C302 1000 25 C306 470 25 C401 1000 35 C502 470 35 C505 1000 10 C506 470 10 C702 470 10
Code:
issue standby / "on" ------------------------------ C3 320V / 318V blue LED off / blinking orange LED off / off Q202 pin i/1 1V / ~1V Q202 pin i/2 0V / 0V Q202 pin i/3 0V / 0,4V Q601 pin i/1 20V / ~0,3V Q601 pin i/2 0V / 0V Q601 pin i/3 22V / ~1V
Paul
