Sorry,no schematic. You should check which IC generates P3V3AL (3VALW) on similar schematics,or take note of the QFN IC`s on the board,if you don`t recognise anything by the marking code then search on google e.g. if you see a QFN marked 51123 search for: 51123 IC ,Marking code 51123, IC marked 51123 .Just try different searches.
Well, this seems to be a bit problem, cause it looks that IC is marked 577BS and I cant find any datasheet. So I have no idea what measurement I should do.
Well, strange thing happened. After some experiments with applying +3V on KBC to make sure it is not shorted or damaged system turned on with some error codes on postcard, so flashed to original BIOS and laptop started with artefacts on screen. Reballed GPU and laptop works like a charm again
---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters.​ ----------------------------------------------------------------------------------------------------------------------------------------------------------
