MacBook pro, AGND
    MacBook pro, AGND
    I am not sure if this has been asked before but, I will appreciate everyone's help from everyone here
    Macbook schematics show gnd and agnd
    Upon checking ohm reading from agnd to a screw hole it is connected
    One of the cap pads goes to agnd that is ripped, so i was thinking to scrape where the agnd pad and make a ground pad
    If I were to connect this cap that goes to agnd to the scraped pad, gnd
    what would happen?
    But why does the schematic show two grounds but practically they are going to the same place?
    Thanks all
    Re: MacBook pro, AGND
    One will be a digital ground while the other is an analog ground. Granted, they are both ground (well behaved ? - small joke); they are different in the following sense:
    https://electronics.stackexchange.co...log%20circuits.
    https://www.analog.com/en/analog-dia...-grounded.html
      Hi
      Thanks for your reply to the post
      I understand there are two grounds, Analogue and digital
      As both grounds are going to the same point would be ok to scrape copper and connect the SMD cap to this ground but this would not be AGND but normal GND
      Thanks all
        Originally posted by lcdcaps1 View Post
        Hi
        Thanks all
        Would this be ok to do
          Yes.
            Yes.
            Thanks mate @mon2
