So, I've got the Nintendo Switch on the bench.
Issue:
* Won't charge up the joy-cons
* Fan is not spinning.
* Battery discharges very quickly
* Serial number from joy-cons unavailable
I have located the shorted diode near the cpu fan connector. Apparently that is pretty common issue. Once the diode has been removed the short is gone.
Apparently it is going to work fine right know without the diode.
But... I understand that this diode someone of course put there for a reason. Problem is I don't have a donor board.
Do you know maybe what are the diode values?
Anyone had that problem before?
Issue:
