hello its been years since i been on here but im back and could use some help.I purchased this tv a few days ago with a reboot loop issue. I brought it home tested it it looped repeatedly. I opened it up snugged every cable and it worked.
Tv was working fine for 2 days then last night it started looping again but this time with lines and patterns all different each loop (see pics).I opened it up again and pulled t-con cleaned it and reinstalled and it works for about 30 min before acting up again.. i found out through research that the T-con currently in it is from a 7100 model Sj does not show it as a suitible replacement so i purchased the correct one for it today. So my question is will the t-con cause this issue or do u think main board? Sometimes if i smack the tv it reboots and comes normal for a sec then scramble again
