60pb660v flogging a dead tv-shop visit req
    Re: 60pb660v flogging a dead tv-shop visit req
    Pin 2 of the ic will conect to the optocpopler, and being broken will likely result in the ic being in burst mode. Burst mode would explain the why you a low voltage on the outputs.
    I can't be sure about where pin 6 would go. I suspect it is part of the circuit that might be used to control the ic in some way.
    In some cases the vcc pin would be connected to a circuit that supplies the vcc voltage after the ic starts up. but this does'nt seem to be the case here.
      Thanks You for the advice will keep you updated but still waiting on delivery of the ic200
        Thanks forall your help- finally replace the cap and the chip 200D6 and its all working now.
        Many thanks to R_J and the others.
