I found a for sure bad cap in my old APC XS1500 UPS, it's a 22uF 400V 105deg electrolytic (CapX branded). Getting that exact value seems expensive, is there a another value I could get away with that's more readily available? It seems to be one of the main caps in the charging circuit (the part of the UPS that's malfunctioning).
APC UPS cap, suitable replacement?
Re: APC UPS cap, suitable replacement?
Originally posted by impala454 View PostI see a 33uF on prime for $8, is that close enough?
If the cap is just being used to store charge (filter), then larger is usually safer.
[No doubt your cap sits on the rectified mains]
BE SURE TO CHECK PHYSICAL DIMENSIONS -- including lead spacing!
