Re: Samsung UE32D5720 permanent reboot
The Samsung D Series TVs Suffer From NAND Flash Failure, The Symptoms Are BOOT LOOP.
Usually The Samsung Logo Appears Then Shuts Down And Restarts Continuously. You Can Check The NAND Flash By Using Freezer Spray On It, With The TV Off, Freeze The NAND Flash I'c Then Turn On The TV. The TV Should Start Normally. If This Is The Case, You Need To Replace The NAND Flash With A Pre Programmed One.
I Have These In Stock £26.00 Plus P+P
