Hello
thanks for any clue on this charging problem!
After 3 or 4 attempts of propper soldering the BQ24780 charger IC the laptop boots up propperly, almost fine for everything except for the battery charging part. It runs from AC only and also from Battery only. when the battery is connected linux says charging 10% but after an hour cells volts are 3.75v each and power supply only draws 390 mah so no charging at all.....
the mosfets look fine all, charging coil close to battery connector is 11.1v when battery present and 10,9v with no battery present. in the charger IC bq24780s BATPRES is always 0vol..!
Check voltage at battery connector pins
With charge plugin only
0,82V at +
data and clk 3,2v
pins in the charger shows:
0,82V at +
data and clk 3,2v
