I have this acer e5-473g A4WAB LA-C341P laptop., the first problem is dead laptop but 19v present on 19v power rail and 3v and 5v alw present on each coil, no i flashed the bios I got here in this forum now when i plugged in orange light present pressing the power button turns on the 1 second goes off,I noticed there is no RSMRST# on pin100 of the kbc no voltage, notice also there is s5, s3 on pin7 and pin8 and no PGOOD on pin10,on pin9 it has only 17v supposed to be 19v of PU501 based on schematics.and also noticed that on pin 27 on the keyboard connector when i plugged the charger alw3.3v is present, but after pressing power button turns on and goes off 3.3v missing on pin27 JKB1 connector. anyone please help
ACER e5-473g a second goes off
Re: ACER e5-473g a second goes off
Better to start from the beginning .
1- Is there any liquid spill or corrosion observed.
2- With diode mode test all coils sarching for short and post all the results.
3- Post your old dump .
4 -PQ 302/303 Drain , source and gate voltages.
5- U28 basic requirementsAttached Files
I built this file for you, try it and report back for any changes.
https://www.badcaps.net/forum/showthread.php?p=1046033Last edited by SMDFlea; 05-15-2021, 04:30 AM.I don't provide help for people using CH341A and a clip.
Originally posted by Sametbey View PostHave you tried the bios program. You can check for short circuit on USB data pins. There are not many options other than audio and ethernet chips. the processor may be problematic.
