List of pin compatible Laptop ICs
This is a sticky topic.
    Re: List of pin compatible Laptop ICs
    AFAIK:
    Suffix Code B1 on NPCE985PB1DX a few pinout have signals/voltages 1.8V only, BE AWARE with code suffix A0 on NPCE985PA0DX most likely have signals/voltages 3.3V.
    Note:
    Need confirm from other experience Techs here.
      Good day guys. I just need to confirm if ic PM6686TR and PM6686 are the same? Coz I want to substitute it for this sn0608098. it takes 20 plus day to order the correct replacement. Thanks
        PM6686 and PM6686TR are the same, the TR means Tape and reel ,its just the type of packaging that the IC`s are supplied in .
          anybody knows replacement for RT8248A ?
            Please, does anyone know the equivalent I.C. for BQ24715?
            Thanks in advance.
                Originally posted by pavel.kinc View Post
                BQ24747 = BQ24745 = ISL88731C HRTZ - test all OK
                Thank a million times Bro
                    Re: List of compatible Laptop ICs
                    isl 95836 and max 8778e compatible with wich ?
                      https://docs.google.com/spreadsheets...it?usp=sharing
                        Originally posted by Weelcup View Post
                        Hi again guys
                        I just decided to replace and check.. and booom it is working!
                        just wanted to share the info with you... all the best everybody
                        thanks man!
                          HI...Voltage controller "39 = 3D" has the equivalent? I didn't find anything about him.
                          thank you..
                            "39=" → Richtek RT7291AGQUF
                              Today, I replaced Max17020 by RT8206B. It worked fine after this replacement in the same circuit.
                                Thk's
                                  MAX17411 what is compatible ic?
                                    Since MAX17411 has many pins, no other IC seems to be compatible to it. It would be better to buy exactly the same MAX17411 model with the same number of pins.
                                      4957agm comptible mosfet?
                                        hi
                                        can any one advise if TPS51285 is compatible replacement for TPS51275?
                                        thanks in advance
                                        Can anyone give meIt8518e datasheet
                                          any equivalent voltage regulator ic for LV5028AGQV? QFN 5x5 40
