Anyone ever notice...
Front - left to right
2N1307 - PNP Ge
2N1924 - PNP Ge
2N1305 - PNP Ge
2N3507 - NPN Si
2N5320 - NPN Si
Rear - left to right
Unknown - NPN Ge
2N329A - PNP Si
2N5322 - PNP Si
Why is this weird?
All TO5/TO39's are E B C looking at the bottom when the center pin away from you.
So this means, on the PNP Ge transistors, BASE is hooked up to the canister! Normally base is the high impedance signal (common emitter, emitter follower). I thought Germanium PNP transistors were used as common base as often as Silicon (not that often), hence this being weird ... or is it?
2N1307 - PNP Ge
2N1924 - PNP Ge
2N1305 - PNP Ge
2N3507 - NPN Si
2N5320 - NPN Si
Unknown - NPN Ge
2N329A - PNP Si
2N5322 - PNP Si
Why is this weird?
