Hi All
Wonder if any one can help ? I have just had a 20" monitor off my brother he said it was working fine but one day when he switched it on the screen flashed on then went dark.
When i switched it on the green light stays on but no picture displayed, when i used a torch i could see the picture , so no backlights.
I took it apart and tested the backlights with my lcd tester i used the inverter included in that kit.
As you can see from the photo's i have included the screen working with my lcd tester connected.
When i check the volts on each backlight plug at switch on the volts jump up then go back down to 0v after about one second.
Can not find any info on this monitor or a supplier for power board ?
Any help much appreciated.
