Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 11-07-2018, 01:45 PM   #1
CapPun
City & State: a yurpean city
My Country: Yurp
Exclamation *insufficient* wattage for GPU causes GPU to *overheat* ? is this magic??
so this a general question - I've read many times that amperage on 12V rails should be sufficient to properly feed a graphics card
makes sense so far
what makes way less sense & sounds like total magic to me is, if a GPU is underpowered (insufficient wattage on 12V rail) then this causes the card to...overheat?
how thef is that possible?
basically that's like saying, if the card doesn't get enough energy then it produces more energy?
that's like saying an underfed sportsman will be able to lift more or something
sounds like this totally violates the most fundamental law of this universe lol (conservation of energy)
could an expert explain plz? (in not too complicated terms)
CapPun is offline   Reply With Quote
Old 11-07-2018, 02:09 PM   #2
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Default Re: *insufficient* wattage for GPU causes GPU to *overheat* ? is this magic??
The switching power supply device that step down the 12V to lower Regulated Voltages to run the GPU will have more current flow through those switching devices when input Voltage is low, those are the devices that will be overheating because they try to supply the same regulated Voltage to run the GPU. But most most card should throttle down.
And when the current draw form 12V exceeds the PS capability then PS may go into shutdown.
Old 11-07-2018, 02:22 PM   #3
CapPun
My Country: Yurp
so basically lower voltage means higher amperage? (so that the product of the two ie. wattage remains constant?)
and by "switching devices" you mean the VRMs on the graphics card? that is what overheats when 12v voltage is too low?
Old 11-07-2018, 02:56 PM   #4
petehall347
City & State: worcester
My Country: United Kingdom
i guess its a bit like a starter motor burning out when using a bad battery .
Old 11-07-2018, 03:09 PM   #5
CapPun
My Country: Yurp
thing is budm mentioned insufficient voltage causing overheat - but my scenario involves insufficient wattage not voltage
for instance suppose the 12V is super stable in voltage & stays at 12V precisely (as in Seasonic-level stable) BUT the wattage (power) on the 12V rails is too low for a graphics card: this will still cause the card to overheat despite the voltage stability right?
if so, why is that?? how can insufficient power (energy over time) cause the card to produce more energy (as heat)?
Old 11-07-2018, 03:27 PM   #6
sam_sam_sam
City & State: Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Are you measuring the voltage on the graphics card or are you measuring the connector for a hard drive that could make a difference on your voltage measurement
Also does your power supply have clean power output which means very low ripple or noise
which could cause problems also if either value is high
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 11-07-2018, 04:21 PM   #7
CapPun
My Country: Yurp
mine was a hypothetical question
but let's assume: output if PERFECTLY clean, zero ripple & noise. let's also assume voltage fed into graphics card stays at EXACTLY 12V with zero variation
Old 11-07-2018, 04:52 PM   #8
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Perhaps have to think it another way, if the GPU is drawing a lot of power - more than what the PSU is able to supply - then the voltage will go down (due to PSU ESR and indirectly wattage rating) and the GPU/device would be generating more heat naturally.
Otherwise the original premise that lower voltage is causing overheating does not make any sense, assuming that the effective resistance of the GPU stays the same. The heat is power dissipation - and power=volts*current. To generate more heat, voltage needs to go up or current drawn needs to go up.
The only thing that could make sense is current going up drastically and voltage trying to stay the same but can't due to ESR.
eccerr0r is offline   Reply With Quote
Old 11-07-2018, 05:00 PM   #9
budm
budm's Avatar
"12V is super stable" Yeah, up to at what load current? 10A?, 100A?
Power supply that can supply 12V with 1A max = 12 watts, 12V power supply that can supply 2A max = 24 Watts. So if the load is trying to draw more current that it can deliver then the output Voltage will drop and then may be to point that the power supply will go into shutdown.
What do you think Watt is? Voltage x Current = Watt (linear load). I think you need to know and understand the relationship between Voltage, current, resistance.
I.E. Supply Voltage is 12V and the load requires regulated 6V at 5A (30 Watts) to run, so the 12V will be fed to switching Buck converter to step it down to be constant 6 and able to supply 5A of current through the load, for the sake of simplification, lest make it zero lost conversion, 100%eff.
So to get 6V 5A (30 Watts) output, the 12V power supply will be drawing 2.5A (30 Watts), if the 12V drops down to 10V, that means the current will go up to 3A to be able to supply the load requirement.
Old 11-07-2018, 05:07 PM   #10
petehall347
was told when i was 11 years old volts are given and amps are taken .
Old 11-07-2018, 06:33 PM   #11
CapPun
My Country: Yurp
ok I didn't know that max wattage of a given rail was related to that rail's voltage stability (that's what your saying right?)
basically insufficient wattage is due to insufficient voltage which in turn causes a rise in amps thus more joule energy wasted - amirite?
if so that makes more sense now I guess
been a while :/ I remember P=UI and U=RI (and P=RIČ)
at least for direct currents (for alternating currents there were also sin/cos functions involved lol)
alrite so now it's been explained how low voltage causes more heat I've another question - how is it that overvolting processors (CPU's, GPU's, RAM... something them crazy overclockers like to do) also increases heat? shouldn't the extra voltage cause the amperes to drop thus decrease heat output?
what does that mean
Old 11-07-2018, 07:32 PM   #12
budm
budm's Avatar
"basically insufficient wattage is due to insufficient voltage which in turn causes a rise in amps thus more joule energy wasted - amirite?"
Nope, if it is just simple non regulated Voltage source (I.E. battery) and a load, there will be no current rise when the Battery Voltage goes down with the fixed load resistance.
Power supply output Z: https://community.keysight.com/commu...haracteristics
When you deal with regulated power supply, the Switching device in the Regulated Switching power supply will try to draw more current to try to maintain the output Voltage to the load when feeding Voltage goes lower. Regulated power supply will draw more input current when Voltage Source that feeds the regulated power supply, otherwise how else it can maintain the output power, it is about power conversion.
Well, it does not sound like you still do not understand Voltage, current, power. You need to do more readings.
So let say you have 1 Ohm resistor connected to 1V source, so how much current will that be? how much power will that be?
Then you hook up the same 1 Ohm resistor to the 2V source, so how much current will that be? how much power will that be?
Do the experiment with power supply you have, let say it has 12V 1 A , so you connect load that will draw 1A and see if the 12v will stay at 12V, then try to draw 4A from it and see if it will stay at 12V or it may go into shutdown.
You do know how to calculate what the resistance should be so it will draw the required current with known Voltage, correct?
Old 11-07-2018, 07:44 PM   #13
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
No, no, no. Again, the current/wattage demand increase is causing the voltage to drop due to ESR of the PSU, not the voltage drop causing current consumption to rise. Big difference here, and the latter makes absolutely no sense from a conservation of energy standpoint. A stronger PSU will still generate as much heat, except that GPU will actually work now since voltages won't sag.
This is also assuming that you're not losing power due to onboard switching regulators wasting power due to not being able to saturate the transistors...which is a different issue. The transistors would be getting hot, not the GPU, which would stay cold because it can't run due to lack of voltage.
Old 11-07-2018, 08:20 PM   #14
CapPun
My Country: Yurp
what's the ESR? googled it but it only appears as a characteristic of capacitors
that's what I meant (I think): if voltage drops then PSU will increase current to compensate to maintain required power correct?
P=UI & U=RI so I=U/R so P=UČ/R so current will be 1A & power will be 1W?
2A & 4W?
resistance should be 12/4=3 ohms? (omega symbol w/e)
but resistance is a fixed amount it cant change right?
Old 11-07-2018, 08:41 PM   #15
budm
budm's Avatar
What is 'U'?
Old 11-07-2018, 09:50 PM   #16
CapPun
My Country: Yurp
voltage (teachers always wrote it as U)
I is intensity & P is power
Old 11-07-2018, 10:29 PM   #17
budm
budm's Avatar
Euro uses 'U' for Voltage which I have not seen it being used in US.
Old 11-08-2018, 01:27 AM   #18
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
ESR = effective series resistance. Does not have to be capacitors - anything that has an ideal characteristic of being zero resistance (capacitors, inductors, power supplies, batteries, op amps, etc.) - has some kind of output resistance in real devices. I just name this resistance as an "effective" series resistance because there's no actual resistor in these devices.
With the resistance, the behavior of the circuit usually is negatively affected - batteries and psus will exhibit droop, op amps can't drive anything and still maintain their gain, capacitors and inductors lose energy just being used...
Old 11-08-2018, 04:38 AM   #19
petehall347
i always thought ESR = Equivalent series resistance
Old 11-08-2018, 09:20 AM   #20
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
that works too. Either way there's no "real" resistor there and ideally there is no resistor, but due to design or real components, there's 'effectively' an 'equivalent' resistor there. It's confusing for PSUs because they have capacitors there that contribute to the effective resistance too, and each of them indeed do for the high frequency component. But there's also the low frequency component/DC that's dependent on the transistors, diodes, and inductors/transformers.
Badcaps.net Technical Forums © 2003 - 2019
