Hi!
I have a 2007 era HP a6110n computer with an Asus M2N68-LA (Narra2) motherboard. This computer has had a dying HD for nearly a year. As the problem was only at startup, I let it go till the end. To that point, no other problems were noted at all though.
I bought a Western Digital 500 gb HD and installed it. I then tried to reinstall Windows Vista using HP restore disks. In repeated efforts, I was unsuccessful with many 'blue screens of death'. I then tried using a Windows Anytime upgrade disk that I got from ebay. Except for an inability to install Windows service pack 1 (oddly SP 2 installed fine) Vista installed properly but the blue screens continued. I then bought a new copy of Windows 7 Professional (and yet another HD later too!). My end result with Windows 7 was a 0x00000124 hardware failure early on in the installation routine. I then reinstalled Vista but was back to the blue screen failures (but unlike '7', it did install again; odd). Alas, I then looked at the motherboard. Having been in ham radio and having run a business rebuilding audio equipment in the past, I noticed a total of 11 capacitors with bulges or leakage. Not good!
Now for the real question: should I replace just the 11 noticeably bad caps or use the kit. I do have a pro soldering/desoldering station available but '6 layer' PC board is a scary thought. I am smart enough to get that! The other question is the cost. The cap kit shipped will be $31.95 whereas a complete mother board for this computer is available from Server Supply for $57 shipped (less CPU and another major removable chip). Of course, I get the same old crummy caps on that board that likely have some shelf aging too but the board is supposed to be new, that aside.
I think that the caps are the problem but I don't know that, of course. They certainly are a problem, to be sure. What would you do?
Thanks!
Jon Hall
Ruckersville, VA. 22968
Thanks!
Jon Hall
