This mb is out of an HP Media Center PC, about 5 years old, model 557z. One day it did not power on. I had replaced the power supply a couple of years ago. It is a small form factor/custom ps. This time when looking up the part it was about $150. It was for my work and they did not want to invest that much into an old computer, so I brought it home to see if I could salvage it, or at least some parts.
I found some bad caps in the power supply, recapped, tested, looked ok. Plugged it into the mb, and saw some smoke between the usb ports and the cpu. Wasn't sure if it was from the caps or the transistors. Turned it off, then for some reason turned it back on and the ps blew the fuse and something else as I am unable to repair it.
Then taking a closer look at the board I noticed 5 bulging caps, and one of the transistors (mosfet) where the smoke was tested bad. I replaced the caps (with Panasonic caps) and transistor (with exact replacement), found another ATX 24 pin power supply (too big to fit inside the case, but ok for testing) and it powered up perfectly. It worked for a couple of hours and then the transistor went out again.
Here is what I need help with: the transistor is the kind that has two legs and the back soldered to the board. I only have a soldering station and don't know how to solder/unsolder these components well. Is it possible the new transistor failed because I was only able to get a little solder tacked onto the back? I also might have applied too much heat trying to get it soldered onto the board. If you look at the first pic you can see the mess I have made trying to unsolder/solder this twice. (I had not cleaned up the flux and extra solder when I took the pic.) I did test with continuity and it seems the board has not been damaged severely.
I still have one more new transistor to try, but wanted some help before trying to attach it again. The only idea I have come up with was to clean it up good, then cover the area with ChipQuick, and place the transistor on that quickly before it hardens. But I don't know if ChipQuick will work over the long term.
The caps that were replaced are the larger caps (two are removed in the pic) I have tested the other caps in the area with an esr meter without removing them, and they test ok, but I don't mind ordering some more and replacing them if they could be contributing to the problem.
I have repaired a lot of LCD monitors with the help of this forum, but this is my first motherboard!
