So I'm trying to solder a as15-f onto a tcon board. I removed the old chip. Put solder paste across the pins and sat the new ic on top and positioned it. I had my rework station up to 400 degrees F. And air at 15-20. As I wave it around the chip I see the solder paste start to flatten out but it never actually melts into solder and goes on the pins. What am I missing with doing this.
Help with hot air station
Re: Help with hot air station
400 deg F is too low. You want 400 degrees C as read by the station. That, at 1cm away it will be 320C at most, which is perfect.
Think of it this way: Lead solder melts at 183C, but you always have to set the iron to at least 300C to get it to melt, because thermal transfer between the tip and the solder will never be 100%. Same goes for hot air.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.
