Asus ROG 751JT Power issues
    Trying to find a schematic for a ASUS G751JT-WH71(WX).
    Problems started with the laptop going from AC to battery and back again when playing games.
    Eventually the battery would completely discharge and not even register the DC jack.
    A few days would pass and it would work again.
    Now there is NOTHING. No lights at all when plugged in. Power button does nothing.
    What I've done/tried:
    1. Replaced battery
    2. Disassembled / reassembled many times ( pulled main / bios battery and held in pwr button for 1+ minutes)
    3. Tested AC - DC power plug and can confirm 19v output (OK)
    4. Tested for 19v at DC mini-board going into motherboard (OK)
    5. No visabable shorts or suspicious items on motherboard. (OK)
    It's 2yrs old, so no warranty stuff.
    I was thinking it could be a blown charging circuit.
    Anyone have any thoughts?
    Thanks for any help you may have.
    Re: Asus ROG 751JT Power issues
    Replace Motherboard can solve your problem Man
      id say try it without the laptop battery in and see if it powers up then ?
      if no go its likely the motherboard has gone bad and would either need repair or replacement
      Samsung UE46D6530
      Samsung BD-F7500
      Samsung HT-ES6200
        Check power pin
