Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Old 11-01-2019, 04:29 AM   #1
Hondaman
Hondaman's Avatar
City & State: Clarksville, Indiana
Line Voltage: 120V 60Hz
I'm a: Forum Junkie
Smile 2-dimensional barcodes
Every autumn/Christmas, I find myself wanting to create some barcodes for use at my workplace. I don't have access or authority to use any software at work for this purpose, so I must rely on "home-built" solutions. These barcodes will be printed out and be laminated on a lanyard around my neck.
I would like barcodes that can be easily resized, so I can find the size that works best for the laser barcode readers that we have.
I would rather have software (and the final barcode files) here on my local machine (no web-based software, and no proprietary formats if possible). The barcodes I will create could range from, I don't know, 16-20 "squares" on both X and Y axis to 32 or maybe more, and probably be around, oh, I don't know, 20-23 millimeters in each dimension (maybe larger for more complex barcodes).
I thought about Inkscape for Windows/Linux; I toyed around with it briefly in 2005, but now it seems full-featured, quite complex and better suited to photo editing.
I suppose the interface would have a "grid". Kind of like working with the gridlines on a 8.5 by 11 inch sheet of paper in a desktop publishing program, but these gridlines would only be for what amounts to a 16 by 16 or a 32 by 32 piece of clipart, basically (the user can choose the exact size beforehand). I could click with a mouse to turn each square white or black, then save the file. That's all I need.
Is this the best way to accomplish this task? I don't need a huge, full-blown piece of software to create one or two barcodes......
Any advice would be greatly appreciated !
Hondaman is offline   Reply With Quote
Old 11-01-2019, 05:59 AM   #2
Curious.George
Default Re: 2-dimensional barcodes
[stuff elided]
Originally Posted by Hondaman View Post
Every autumn/Christmas, I find myself wanting to create some barcodes for use at my workplace. These barcodes will be printed out and be laminated on a lanyard around my neck.
I suppose the interface would have a "grid". I could click with a mouse to turn each square white or black, then save the file. That's all I need.
Assume you can create a grid "template" that just needs "squares" that are white or black (that may not be possible, depending on the code you are using), you could create a bunch of adjoining squares/rectangles in something as crude as MSPaint, choosing "black" or "white" for the fill color of each square that you draw.
MSPaint sucks in that it forgets the objects you've created as soon as you've created them (e.g., it "flattens" the drawing after each operation). So, a better tool would be something that treats the squares as individual objects that you can LATER alter (select object, pick new color, lather, rinse, repeat)
Something like Illustrator, CorelDRAW/PAINT, etc.
But, this leaves you with the responsibility of creating the individual "squares" having the correct dimensions relative to the symbol as a whole.
An easier solution is just to find one of the many barcode generating tools, specify the barcode of interest and then just type the desired text -- letting the tool create the symbol at whatever size you require.
Curious.George is offline   Reply With Quote
Old 11-01-2019, 06:38 AM   #3
stj
stj's Avatar
City & State: Europe
there is lots of software to print barcodes.
Old 11-13-2019, 07:24 PM   #4
Huscarl17
City & State: Quincy IL USA
A free barcode generator
https://www.barcoding.com/resources/barcode-generator/
It's at the bottom of the page.
I use it to correct UPC's on gaming products and hang tags for product in our hobby shop.
Huscarl17 is offline   Reply With Quote
Old 11-15-2019, 08:57 AM   #5
Uranium-235
Muffins
Uranium-235's Avatar
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
He said no web based software
Uranium-235 is offline   Reply With Quote
Old 11-15-2019, 10:48 PM   #6
gg1978
City & State: Jamestown, IN
Line Voltage: 117VAC, 60Hz
I recall there being a command line 2d barcode generator, although the name of it i am drawing a blank on at the moment. Just found it, it's qrencode from linux..
https://fukuchi.org/works/qrencode/
gg1978 is offline   Reply With Quote
