Ok I was given this tv and all i knew was it dosent go.. so i plugged it in and the standby light goes from green then starts to flash once every second or so,not sure if this is the same as a plasma blink.
Anyway i have found it very hard to find any info at all about this tv.
I have tested the standby voltage on the power board which reads 5.2v so im guessing close enough to the 5.3v on label but the 16v test point reads 0v as does the 35v.
I then removed the power board and discovered a heated patch on the board around one of the FETS which i have replaced but still have the same result...So would be grateful if anyone could give me a few pointers on what to check next..could it be a different board thats the problem?
Im In New Zealand So i know the z at the end of the model number is for New Zealand area.
I will add some pics when i can figure out how to get them on here from my phone.
Thanks For any help.
Nick.
Nick.
