820-2936 B not turning on with adaptor.
    Not turning on with adaptor but with battery the laptop is turning on,.
    And also battery is not charging. I changed the PU7000. PU7000 pin no 14 is 3.3V.
    now what should i check?
    GREEN LIGHT of mega Safe is there.
    Re: 820-2936 B not turning on with adaptor.
    Voltage on PPBUS_G3H with AC adapter only, battery disconnected?
    Voltage on PM_BATLOW_L with AC adapter only, battery disconnected?
    Resistance between pin 27 and 28 of U7000? Resistance between pins 17 and 18 of U7000?
      CHECK FIRST R6990(47 ohms) then D6990 double diods and also check F6905 and D7005.
        Why should he check R6990, D6990 and F6905 if magsafe light is there. D7005 makes sense. Trying to learn am i missing anything?
        Resistance on R7020 like piernov said
        U7000
        voltage on pin 2, 3, 13
          U7000
          yes you are right....i missed magsafe Green light part in the post....
