Induction hob power board
    Hello, could anyone help with the resistor value for this resistor, my induction hob has a fault code after having a close look i found this resistor is cracked.
    Re: Induction hob power board
    It's too hard to make out the colors reliably in your photo with the lighting you have.
    Try this if it makes things easier for you:
    https://www.digikey.com/en/resources...or-code-4-band
      Ok thanks, i think it has been hot and discoloured slightly i would say that the 2 first are orange then black and gold which makes it 33 ohm. Thanks
