List of Bad Cap Manufacturers
This is a sticky topic.
    Re: List of Bad Cap Manufacturers
    Originally posted by Heihachi_73 View Post
    I've never heard of this brand either. This Anodia 1000uF 16V cap was in a dead Telstra TT-300-6B cordless phone wall wart from 1997. Transformer was open on primary (19 ohms on secondary).
    The negative stripe is identical to Su'scon. Note the basketball-shaped vent...
    I've seen those a few times. All were good, but yes, they are old.
    Muh-soggy-knee
      ABAcon, on a 56K modem
        Wow, what an eye opener.
        Did not even realize there were THAT many brands of Elytics....but I am not into computers.
        In the guitar amp world we pretty much see:
        TAD
        F&T
        IC
        Xicon
        Nichicon
        IC had a bad run of 20/450 axils a few years back. I guess it was the whole... bad Elytic Paste scenario.
        Other than that, we do not see any failures to speak of.
        best
        26+6=1
          TAD
          F&T
          IC
          Xicon
          Nichicon
          best
          Yeah, Nic components had some bad runs of capacitors too.
          Never heard of TAD capacitors, have any pictures?!
          Muh-soggy-knee
            Here you go.....
            http://www.mojotone.com/amp-parts/ca...ube-amp-doctor
            26+6=1
              Never seen this brand before, but they look exactly like HEC primary caps, except with a different name with a stupid font. I doubt they're actually rated for 105C (except maybe for an hour ) and they're probably 330uF....i will check soon
              Edit: Wow, actually 470uF...
                I've never seen those before! :O
                Muh-soggy-knee
                  Maybe K-Eagle is the next Panasonic?.... Okay, I seriously doubt that
                  But hey, at least they got the right capacitance and not lying about it. As long as they can hold it.
                    Is that Comic Sans?
                      I love seeing brands I've never seen before even if they suck They're good size and actually have some weight to them. Although the bung on them is pretty strange, I will upload a picture of that later
                      I think it is comic sans. pretty sad?
                        well I never thought I would be calling out our beloved Sanyo (Suncon), maker of the legendary WG series, but I just cracked open a Dell computer with MANY leaking and bulging caps, and all of them are Sanyo WF series
                        the BIG 4
                        ~~~ the top tier of low-ESR electrolytic capacitors ~~~
                          Pictures? Were they on a motherboard? Maybe it's your PSU's fault
                            Others bore witness to a similar problem:
                            https://www.badcaps.net/forum/showthread.php?t=15903
                            https://www.badcaps.net/forum/showth...=WF#post332849
                            https://www.badcaps.net/forum/showth...=WF#post285834
                            Maybe Sanyo WF is a defective series, or maybe there are fakes going around... or maybe it's just the fact that they were used in a hot case since they are aqueuous capacitors and, judging by their specs, are probably pretty high on the spectrum relative to their water content ("ultra" low ESR electrolytic capacitors tend to be) - those kinds of capacitors dry out much quicker with added heat. They are rated for 2,000 hours @ 105*C, while I believe WG is double that.
                            Seems every Japanese manufacture has their share of bad capacitiors, almost. Nichicon - HM/HN 2001-2004 (most of those batches, anyway). United/Nippon Chemi-con - KZG/KZJ and TMZ/TMV (maybe another).... Rubycon, select batches of MBZ/MCZ. And now Sanyo/Suncon with WF. Barring the 1990s fiasco which Elna was included in, Panasonic seem to be the only Japanese brand that doesn't have a problematic series... I really hope the Japanese brands aren't dropping in quality, though...
                              Not only is the K-Eagle logo in Comic Sans, they couldn't even find the "ยต" sign and used uF instead. FAIL.
                                Good catch That is pretty bad...
                                  ^ ... And all for a total of four hundred and seventy you EFFs
                                  (abbreviation for ultra-Farads?? Or unlimited Farads perhaps )
                                    Originally posted by Wester547 View Post
                                    Seems every Japanese manufacture has their share of bad capacitors, almost. Nichicon - HM/HN 2001-2004 (most of those batches, anyway). United/Nippon Chemi-con - KZG/KZJ and TMZ/TMV (maybe another).... Rubycon, select batches of MBZ/MCZ. And now Sanyo/Suncon with WF. Barring the 1990s fiasco which Elna was included in, Panasonic seem to be the only Japanese brand that doesn't have a problematic series... I really hope the Japanese brands aren't dropping in quality, though...
                                    You forgot Nichicon PF (M) series from the mid-1990's in your list of bad Japanese cap series
                                    the BIG 4
                                      Well, when I said "barring the 1990s fiasco", I meant exactly that, which includes both Rubycon, Nichicon, and United/Nippon Chemi-con, along with Elna - they all had problematic series back then. I still think even those capacitors aren't quite as bad as the faulty run of HM/HNs, KZG/KZJ/TMx, and Sanyo WF, though, and maybe even MBZ/MCZ... some are even of the impression that KZH could be faulty but that might just be a low tolerance for heat relative to the water content in KZH.
                                        In defense of Rubycon, MBZ/MCZ seem to be weak rather than bad, if other capacitors have problems on the board, then the Rubycon's fold up like a cheap suit! - or if there is abnormally high heat or ripple.
                                        Yes! - I forgot to mention a lot of the quaternary ammonium compounds series from the 90's that you are referring to, that have very high failure rates when they get older - Nichicon PF is the most notable, but there were MANY other series that used this failed technology including:
                                        Nichicon: RZ, RT, VZ, ET, PR, PY, PF, PL, PQ, PG, MX, WX, WP, MP
                                        Nippon Chemi-con: LXF, TXF, SXE, SXG, MVK, MFK, MVF, MFF
                                        ELNA: RSH, RSG, RSE, RC2S, RC3S
                                        unfortunately, I do not have a comprehensive list like this concerning Rubycon and Panasonic, but they had some too.
                                        the BIG 4
                                          I don't know whether Nichicon reformulated the electrolyte, or whether they switched to a different electrolyte, but the PR and PL series continued until being discontinued due to RoHS. The PS and PM series are RoHS-compliant versions of PR and PL (respectively).
                                          PeteS in CA
