Good Day
I have this unit ACER E5-473 with board number LA-C341P. The first complain of the owner on this unit is that power on but no display and wont turn off.
Now after I disassemble the unit to make some reset by removing the battery and press the power button for 30 seconds and place again the battery and the adaptor and turned on and problem now is that it will shutdown after 2 seconds, fan turns on and the current consumption if about 0.220 Amp. I check all the power on all coil and found out that vga_core supply is missing, so I tried to reflash the bios and try again and I can now measure 0.901V on vga_core but still it will shutdown. here are the readings I got on all the coil.
1.35VP PL502 -1.379v
1.05VSP PL602 - 1.058
VGA_Core PL1203 - 0.901
VGA_Core PL1202 - 0.901
BATT PL302 - 3v
+1.5VSDGPUP PL1002 - 1.533v
CPU_Core PL802 - 1.7v
+3V ALWP PL402 - 3.3v
+5V ALWP PL404 - 5.0v
BATT PL302 - 3v
