Ok I have a Panasonic TC-P50VT20 TV that is exhibiting a 10 blink code error.
I have done some basic troubleshooting and hopefully someone could shed light on what is happening so I can replace/repair the correct board.
I have read the few documents on this issue related to 2010 models and it basically says, it's the A board, P board, SS board, or SC board.
I also read through this page https://www.badcaps.net/forum/showthread.php?t=46753 and they had similar problems.
What I have tested so far.
No visible arcs, marks, blown components, but the SC board side of the TV smelled a little off, like electrically burned smell.
Tested SC2 connector on SC board for short. Seems good. Removing SC2 connection and turning on gives 7 blinks, but I think that is normal.
Tried to do the A board isolation test by disconnecting P6 and P7 on P board, disconnected D5 ribbon from D and A board, and also installing a jumper on P34 connector from pin 1 to pin 3. My P7 cable has a
a jumper between pins 12 and 14, so I also tried it there as well. Did not get a white screen.
Tested "After Power SW ON,F_STB 15V outputs at P6’s pin 9 15V outputs at P6’s pin 1 before Shutdown?" I get 15V on Pin 9 but I get 0V at Pin 1 for that 15 second period.
Panasonic's documentation say bad P board, but I want to make sure I am not missing something.
Thanks for any help.
Edit: I have dealt with a few panasonics, and it seems to always be SC related, and that smell of burnt electrical had my brain thinking, so I did a another look around, and I think i may have found my culprit.
Do my symptoms look to be just a bad SC board and nothing more?
