Good morning all -
I have an interesting one today. I'd like to get some feedback on the feasibility of fixing this one before i put parts/cash into it.
Basic info:
TV: UN40EH5300FXZA
Panel: CY-DF400BGLV1H
Main board: BN94-06882E
T-CON - BN95-01211A T05
Power: BN44-00666A (L40GF_DDY)
Notes:
-Power rails to the main board appear to be stable. (13V, and 5V present).
I picked up a Samsung UN40EH5300FXZA the other day. When I power it on, i notice a 4 inch wide stripe on the right hand side of the screen, but the TV image remains dark. After opening the TV, i noticed the T-CON is mounted at the bottom of the unit. (From here on out, I'm working with the TV upside down so i can easily access the T-Con.)
There are 3 blue LEDs on the T-Con:
As-is, when i turn the TV on, all three LEDs illuminate for a split second, then LED2 and LED3 turn off. LED1 stays on. I found a high resolution image of the board from shopjimmy.
If i disconnect the left ribbon cable to the panel then all three LEDs illuminate and the TV appears to boot up and i see the Samsung Smart TV logo on the other half of the panel. Interestingly though, the 4" wide bar is still present against the white background.
The opposite is true as well, if i only leave the left ribbon cable connected to the T-CON, all three T-CON LEDs stay on. Seems like it's over-currenting.
The presence of this bar seems to indicate to me that the panel is bad. Thoughts? Is this worth taking apart to look at the bond tab or the circuit board the T-Con attaches to?
Thank you,
Thomas
Basic info:
TV: UN40EH5300FXZA
Notes:
- LED1 - 12V (?)
- LED2 - (?)
- LED3 - AVDD
Thank you,
Thomas
