Old 11-08-2018, 11:58 AM   #1
Rickig
City & State: Kent
My Country: England
Default Led array
Hi all
Just wondering what you guys use to refit the Led diffusers once youíve replaced the bad smd led.
Rickig is offline   Reply With Quote
Old 11-08-2018, 12:29 PM   #2
dani502017
Banned
City & State: Bucharest
My Country: Romania
Line Voltage: 230v-50hz
I'm a: Hobbyist Tech
Default Re: Led array
Originally Posted by Rickig View Post
Hi all
https://www.walmart.com/ip/2pcs-220V...21mm/125800679
dani502017 is offline   Reply With Quote
Old 11-08-2018, 12:59 PM   #3
Rickig
City & State: Kent
My Country: England
Not sure what thatís for
Old 11-08-2018, 01:14 PM   #4
dani502017
Banned
My Country: Romania
You buy those PTCs and build something like that
https://www.youtube.com/watch?v=EZVQKEp6jxk
For Led diffusers i use BISON ADHESIVE PLASTIC
Old 11-09-2018, 07:11 AM   #5
bobbyskillz
bobbyskillz's Avatar
My Country: United States
Line Voltage: 120VAC 60Hz
I just use cheap super glue as an adhesive for the lens. I use a hot air station to remove the old SMD LED.
bobbyskillz is offline   Reply With Quote
Old 11-10-2018, 02:26 AM   #6
Rickig
City & State: Kent
My Country: England
What temperature is your hot air set to?
Old 11-10-2018, 11:32 AM   #7
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
To some extent it will depend upon the device and the manufacturers data sheet, I don't really have a temp set in mind for my pace hand tools, but aim for between 260 and 300 degrees if there is a large thermal mass indicated then higher. It all really depends on experience.
llonen is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2022
