Old 10-30-2015, 01:52 PM   #1
Rickig
City & State: Kent
My Country: England
Default Bush s642f factory reset
Finally got the set powered up but it won't tune.
It stays on atv 901. Checked the locks and all off so want to try a factory reset but can't figure it out.
Any body know how to do a factory reset on a bush?
Rickig is offline   Reply With Quote
Old 10-30-2015, 02:07 PM   #2
Rickig
City & State: Kent
My Country: England
Default Re: Bush s642f factory reset
Managed to do a factory reset but still not finding any freeview.
Any suggestions
Old 03-23-2016, 12:51 AM   #3
jczarniak
City & State: Coventry
My Country: UK
Any suggestions
I've got same TV and same problem.
Did you managed to fix it?
jczarniak is offline   Reply With Quote
Old 03-23-2016, 12:52 AM   #4
jczarniak
My Country: UK
How to do factory reset, please?
Old 03-23-2016, 01:39 AM   #5
jczarniak
My Country: UK
Managed to do a factory reset:
MENU, 8, 8, 9, 3
but still not finding any Freeview channels.
Any suggestions?
Old 03-23-2016, 05:11 AM   #6
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
Is it scanning for channels and saying none found?
dick_barton is offline   Reply With Quote
Old 03-23-2016, 05:47 AM   #7
jczarniak
My Country: UK
Exactly, 0 channels found.
Old 03-23-2016, 05:52 AM   #8
dick_barton
My Country: Wales
Have you checked the voltages on the tuner? It may have lost it's supply.
Old 03-23-2016, 06:01 AM   #9
jczarniak
My Country: UK
Not sure how can I do that.
Recently changed 4 caps on power supply (4 x 470uF/35V), screen backlight was flickering. OK now but no Freeview.
Old 03-23-2016, 06:05 AM   #10
dick_barton
My Country: Wales
Does it have both an analogue and Digital tuner. If so are you auto tuning the Digital channels
Old 03-23-2016, 06:18 AM   #11
jczarniak
My Country: UK
Has got both tuners.
I'm auto tuning both, tried separately also.
Result is 0 channels found for both tuners.
Old 03-23-2016, 06:19 AM   #12
dick_barton
My Country: Wales
Have you got a schematic?
Can I assume that all the other inputs are working?
Does it say "XX Channels found" but just not storing them?
Old 03-23-2016, 06:28 AM   #13
jczarniak
My Country: UK
No schematic.
All inputs are working.
It say: 0 Channels found
Old 03-23-2016, 06:34 AM   #14
dick_barton
My Country: Wales
Can you guarantee that you have a strong signal from your aerial. Have you plugged the aerial into another set to be certain it's not an aerial/aerial cable fault.
Old 03-23-2016, 06:38 AM   #15
jczarniak
My Country: UK
Yes, aerial is fine, working absolutely fine on other TV.
Old 03-23-2016, 06:46 AM   #16
dick_barton
My Country: Wales
Can you supply a sharp photo of the power supply connector showing any legend alongside giving the voltages read.
Can you also supply a photo of the main board.
Old 03-23-2016, 07:07 AM   #17
dick_barton
My Country: Wales
There appears to be a 5V regulator feeding the tuner and several metal oxide resistors around the tuner you could check out.
Old 03-23-2016, 07:17 AM   #18
jczarniak
My Country: UK
Good idea.
I'll check that.
