Old 10-30-2015, 11:34 AM   #1
mattstolte
City & State: massillon ohio
My Country: usa
Default where to buy single smd led to fix strip
was wondering if anyone knows where to buy single smd leds to repair led strips?
mattstolte is offline   Reply With Quote
Old 10-30-2015, 11:43 AM   #2
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
Default Re: where to buy single smd led to fix strip
You would need to specify the type, rating, dimensions, colour (warm/cool/neutral white) etc. Digikey is a good place to start.
Free service manuals: http://www.toms-service-manuals.com/ -- 72 LED/LCD TVs, 5 monitors, 28 plasma TVs, and 2 AVR 6.1 amplifiers fixed! -- I repair Pioneer 9G Plasma Main Boards & KRP-M01 Media Receivers (PM me for info)
2 Pioneer KURO 9G, 12 Panasonic LCD/Plasma, 1 Sony LCD, 1 NEC Plasma, 2 Yamaha HTS, 5 Sharp LCDs, 5 Toshiba LCDs, 7 Philips Plasma/LCD, 1 Hitachi Plasma, 11 LG LCD/Plasma, 18 Samsung LED/LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Grundig LCD, 1 Dell LCD, 1 iiyama LCD, 1 Acer LED, 1 Logik LCD, 1 Baird (China) LCD, 6 Bush LCDs, 22 Vestel LCDs (Best->Worst)
Old 10-30-2015, 11:45 AM   #3
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
+1.
also: https://www.superbrightleds.com/cat/component-leds/
The one used in TV will have > 100mA rating.
Old 10-30-2015, 11:52 AM   #4
ReeceyBurger123
Never Give Up !
ReeceyBurger123's Avatar
City & State: Telford
My Country: Britain
Line Voltage: 240 VAC 50Hz
I'm a: Student Tech
you would need to specify the type, rating, dimensions, colour (warm/cool/neutral white) etc. Digikey is a good place to start.
+1
ReeceyBurger123 is offline   Reply With Quote
Old 10-30-2015, 04:01 PM   #5
mattstolte
My Country: usa
I am unsure of how to find the ratings for these. Normally I would just buy some used strips to get the tv working. But I would like to start repairing the strip with replacement leds. They are the common strips that are in the 47 lg 47 vizios I have replaced many of the strips. But I can make alot more.money by repairing them
Old 11-01-2015, 12:44 AM   #6
Rickig
City & State: Kent
My Country: England
I recently repaired a strip using some bought from maplins.
http://www.maplin.co.uk/p/white-led-n67jq
Rickig is offline   Reply With Quote
Old 11-01-2015, 05:28 AM   #7
thoma
City & State: Germany
My Country: Germany
http://www.ebay.com/bhp/led-backlight-strip
http://www.shopjimmy.com/tvs/tv-led-light-strip available over proxy see:
:http://www.badcaps.net/forum/showthread.php?p=590506
http://www.ohmsupplies.co.uk/epages/...ts/LED01-Z1.01 LED STRIPES
thoma is offline   Reply With Quote
Old 12-14-2015, 09:57 AM   #8
f67bird
Technician
City & State: Near Savannah Georgia
If you saved the old strips, you can scavenge the working leds from them.
In my experience, most of the leds are still good... depending on how they fail.
On some strips, the leds short, which causes lots of them to short eventually.
Most seem to open when they fail, on these strips there are usually one or two bad... and the rest are still good.
And turn the backlights down after the repair, also instruct the owner of the set to keep the backlights turned down to get them out of what I call "roman candle " mode.
The nicer sets will have separate settings for each input, so you have to go through each inputs setting.
If you don't do this, the set will be back...
Learner
f67bird is offline   Reply With Quote
Old 12-14-2015, 10:02 AM   #9
paulstef
paulstef's Avatar
City & State: Quebec
My Country: Canada
Line Voltage: 120VAC
That's really the cheapest method, take old strips and use the LEDs that are still ok. You don't even need to solder the LED (which sometimes can destroy the LED when heated to much). Just cut part of the PCB from an old defective strip containing a good LED and glue it onto the strip to be repaired.
paulstef is offline   Reply With Quote
Old 12-27-2015, 10:09 PM   #10
Wizard76
City & State: rusk,TX
My Country: usa
Here is what I made work.
Digi-key part#1416-1526-1-ND
The solder pads underneath the are opposite than the Toshiba/LG
cathode has larger heatsink on new ones I replaced so,
I turned them according to the pads on pcb and then reversed the polarity at connector end.
I could not tell any difference in the picture.Must replace all on that strip or rewire.
Wizard76 is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2022
