Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 11-29-2012, 05:53 PM   #1
Bxscig
City & State: Dumont, NJ
My Country: USA
I'm a: Knowledge Seeker
Default SAMSUNG LN46A550 P3FXZA - Weird Contrast & Discoloration issue
I have a SAMSUNG LN46A550P3FXZA that just started with this weird issue of like extra snow like distortion. I am not sure if it the main board, cable, LCD or what not.
Does anyone know what it may be from these pictures? It happens across all inputs. When I took it apart to get part numbers, I powered it on with the back off for the heck of it and it worked for about 2 hours and was still good. I shut it off, put he back on and then the issue was there as soon as I turned it on. Sometimes it takes about 5 to 10 mins for the issue to appear when the TV is started but sometimes it is instant.
Here are some pictures
http://www.nyblacktl.com/samsung/IMG_2010_resize.jpg
http://www.nyblacktl.com/samsung/IMG_2012_resize.jpg
http://www.nyblacktl.com/samsung/IMG_2013_resize.jpg
http://www.nyblacktl.com/samsung/IMG_2014_resize.jpg
http://www.nyblacktl.com/samsung/IMG_2015_resize.jpg
http://www.nyblacktl.com/samsung/IMG_2045_resize.jpg
I have been having a hard time trying to find another main board to see if that is the issue as it was with another Samsung TV I have - LNT-4665F... 2 for 2 have issues within 2 years... just my luck. Any help would be appreciated.
Bxscig is offline   Reply With Quote
Old 11-29-2012, 05:54 PM   #2
Bxscig
My Country: USA
Default Re: SAMSUNG LN46A550 P3FXZA - Weird Contrast & Discoloration issue
I don't have the pictures of the parts where the white/bright parts just look WAY TOO bright.
Old 11-29-2012, 05:55 PM   #3
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Professional Tech
Try this.
TV power off (in standby.)
On remote: Info Menu Mute Power (TV should power on with service menu)
-OR-
If this does not work, turn it off again, then try on the remote Mute 1 8 2 Power... some models use that code instead.
When in the service menu, select "Reset" or "Factory Reset".
__________________
Free service manuals: http://www.toms-service-manuals.com/ -- 72 LED/LCD TVs, 5 monitors, 28 plasma TVs, and 2 AVR 6.1 amplifiers fixed! -- I repair Pioneer 9G Plasma Main Boards & KRP-M01 Media Receivers (PM me for info)
2 Pioneer KURO 9G, 12 Panasonic LCD/Plasma, 1 Sony LCD, 1 NEC Plasma, 2 Yamaha HTS, 5 Sharp LCDs, 5 Toshiba LCDs, 7 Philips Plasma/LCD, 1 Hitachi Plasma, 11 LG LCD/Plasma, 18 Samsung LED/LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Grundig LCD, 1 Dell LCD, 1 iiyama LCD, 1 Acer LED, 1 Logik LCD, 1 Baird (China) LCD, 6 Bush LCDs, 22 Vestel LCDs (Best->Worst)
tom66 is offline   Reply With Quote
Old 11-29-2012, 07:24 PM   #4
Bxscig
My Country: USA
Quote:
Originally Posted by tom66 View Post
Try this.
-OR-
Thanks I will give that a shot. Does that just reset the video settings back to default?
The discoloration as well as the location of it changes... sometimes its blue, sometimes its reddish or its the white but I will give it a shot.
Hope to report back soon!
Old 11-29-2012, 07:36 PM   #5
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Yes, it resets everything. The TV will power on again as if it is new from the retail box. So if you have any important calibration or particular picture settings, back those up.
One thing I forgot to mention was that you must press the buttons in sequence, not all together at once.
I have seen this before on a Sharp LCD TV, but it only affected green. Just needed a reset.
It could also be incorrect panel config -- especially if it occurred suddenly -- or T-con motion-processor fault. (The 100/120 Hz frame doubler this TV uses has lots of overheating problems causing odd artefacts.)
I have the LE40A656, very similar TV, I have fixed two of them. The T-con board failed on one (green lines -- but fixed in location), bad capacitors on the other. I kept the second one, but I found the motion enhancement to be very annoying, so quickly turned it off.
Old 11-29-2012, 07:56 PM   #6
randtek
City & State: US Midwest
My Country: US
Line Voltage: 120VAC 60Hz (allegedly)
I would try cleaning the connectors of the LVDS cable. They can cause some weird symptoms. I do this by disconnecting the connectors, cleaning the contacts by burnishing with a pencil eraser, then cleaning with an electronic contact cleaner such as "Blue Shower". I have fixed a lot of picture issues with this technique.
randtek is offline   Reply With Quote
Old 11-29-2012, 08:08 PM   #7
tw2005
tw2005's Avatar
City & State: QLD
My Country: Australia
Line Voltage: 240VAC
I'm a: Forum Junkie
There's some data in these, may or may not assist.
PDF was simply was too big.
looks like there's service menu (what TOM has mentioned)
Plus a HIDDEN Service menu. Looks like there's some onboard test patterns there as well.
How to enter the hidden factory mode.
a. into the factory mode
b. key input : 0 + 2 + 1 + 4 + exit
c. select option byte menu -> in menu -> out menu
(... hidden menu appear...)
** hidden menu : Video/Scaler, Enhancement, SOUND, Dynamic Contrast, LNA+
- FBE3(image enhance IC) generate internal pattern
Samsung_LN32A550P3F_LN37A550P3F_LN40A550P3F_LN46A5 50P3F_LN52A550P3F_ch_GPR3X_4X_5X
tw2005 is offline   Reply With Quote
Old 11-29-2012, 08:14 PM   #8
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Wait a minute... there's a hidden menu inside the hidden menu?
Old 11-29-2012, 08:19 PM   #9
tw2005
tw2005's Avatar
City & State: QLD
I'm a: Forum Junkie
Or is it a hidden menu, in a hidden menu which is hidden? LOL
Old 11-30-2012, 03:42 PM   #10
hijodalgo
that's T-Con board problem..
hijodalgo is offline   Reply With Quote
Old 11-30-2012, 03:57 PM   #11
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Whilst it does look like a T-con board problem, it was a config problem on the Sharp LCD I fixed.
Old 02-11-2014, 02:55 PM   #12
T-Rex
City & State: South Florida
My Country: USA
Hi, I have what I think may be a similar problem but factory reset and reseating cables on tcon did not fix it. I will create a new thread with pictures.
T-Rex is offline   Reply With Quote
Old 06-09-2014, 02:02 PM   #13
suzannetodd1
City & State: Ocala Florida
My Country: USA
I saw a post on here that someone bought a repair kit for T-con (as I am having the same prob with my TV). My question is how easy is it to repair a T-con or do I need to take it to professional????
suzannetodd1 is offline   Reply With Quote
Old 06-09-2014, 02:05 PM   #14
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Have you ever done any surface mount soldering? In particular a 48 pin chip with leads 0.8mm apart?
If so you can do it - if not you should ask a professional.
Old 07-26-2015, 09:29 PM   #15
onrushmatt
City & State: PA
My Country: US
Question Re: SAMSUNG LN46A550 P3FXZA - Weird Contrast & Discoloration issue
I have the same tv (Samsung LN46A550P3FXZA) and I am trying to figure out if my T-con board needs to be replaced, or just some caps.
I have light experience in working with circuit boards but feel confident in some basic soldering. I have attached a picture of the service menu, which I heard may be a way to fix the issue with the picture. My options are 'Option Byte' 'White Balance' 'B/B Movie' EPA Standard' 'Sound' 'Hotel Option' 'EDID' 'CHECKSUM' 'View Log' 'Front Data Viewer'. I assume the options between will be available once clicked into a menu.
I also attached a photo of the picture issue as well. I think it is the same as the OP's.
I would really appreciate any information or tips, and hope this old thread can bring me some answers.
Also threw in a photo of the model on the side of the console.
onrushmatt is offline   Reply With Quote
Old 07-26-2015, 09:55 PM   #16
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Bad GAMMA Voltage ref. IC, Look for AS15 IC on the T-CON board.
__________________
budm is offline   Reply With Quote
Old 07-28-2015, 05:57 PM   #17
Kallla
City & State: Atlanta
My Country: United States
I have some similar (or not?) symptoms on my home TV a Samsung LN32B650T1FXZA ... attached a picture of how image look (image remain with high luminosity regardless of input source used).
Any taught, help or information to speed-up debugging is highly appreciated !
Kallla is offline   Reply With Quote
Old 07-28-2015, 06:53 PM   #18
budm
budm's Avatar
My Country: USA
Look at the T-CON board to see if it has GAMMA IC AS15, or AS19, very likely to be your problem.
Old 03-22-2020, 07:17 PM   #19
Fix4Fun
City & State: Bath, NY
Smile Re: SAMSUNG LN46A550 P3FXZA - Weird Contrast & Discoloration issue
I had this exact model of TV: LN46A550P3FXZA with the exact same problem, weird colors on the screen: sometimes white where black should be and red spots pixels, pixelating, depending on the input used. It was the T-con board (not the motherboard despite the differences in the inputs). When I got a brand new T-con board (model #: V520H1-C06) from eBay for $32, and swapped out the old one, all my problems went away! I hope this helps someone else considering replacing their T-Con board!
Fix4Fun is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
