Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 04-29-2016, 11:04 AM   #1
Rickig
City & State: Kent
My Country: England
I'm a: Knowledge Seeker
Default Picture fault on le40m86
Hi guys.
I'm probably answering my own question here but I have the above mentioned set that had the clicking fault. I replaced the bad caps and the tv powered up. I noticed however the freeview wasn't working so I removed the main AV and replaced the eeprom.
Fired tv back up and now the picture is all funny, pink and purple etc. So I immediately thought tcon gone down t400hw01 as it suffers a similar fault.
Replaced tcon. Fault still there, tried new main AV, fault still there, tried a different psu and fault still there.
Just seems odd that it was fine until I changed the eeprom. I even tried another eeprom and fault still there.
Any ideas? Or shall I concede and say it's the panel?
Thanks in advance
Rickig is offline   Reply With Quote
Old 04-29-2016, 11:07 AM   #2
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Default Re: Picture fault on le40m86
' I replaced the bad caps and the tv powered up. I noticed however the freeview wasn't working so I removed the main AV and replaced the eeprom. ' So before replacing the EEPROM, do you get good pictures using other Video sources?
__________________
budm is offline   Reply With Quote
Old 04-29-2016, 11:33 AM   #3
Rickig
City & State: Kent
My Country: England
Yes picture was fine. That's why I'm scratching my head.
Old 04-29-2016, 11:35 AM   #4
Rickig
City & State: Kent
My Country: England
Here's a pic
Old 04-29-2016, 11:35 AM   #5
budm
budm's Avatar
My Country: USA
May be you have to get into the service menu setup screen (MUTE, 1. 8, 2, POWER) and check the panel setup, LVDS signal format, etc. May be the EEPROM was not made for that TV chassis.
It has wrong GAMMA Voltages right now.
Old 04-29-2016, 11:39 AM   #6
Rickig
City & State: Kent
My Country: England
Pm me your number talk me through it. But I've tried 2 other good main boards
Old 04-29-2016, 11:39 AM   #7
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
Hello Rickig,
Can you post a picture for us to see how it is now.
You beat me to it. Sorry.
dick_barton is offline   Reply With Quote
Old 04-29-2016, 11:43 AM   #8
Rickig
City & State: Kent
My Country: England
Tv clicks to come on as soon as you hit 1. I normally do info menu mute power. Is that same?
Old 04-29-2016, 11:44 AM   #9
dick_barton
My Country: Wales
The picture looks similar to what happened to me recently when I changed a mainboard. I had to replace the SPI chip from the old board onto the new board then everything was back to normal.
Old 04-29-2016, 11:45 AM   #10
budm
budm's Avatar
My Country: USA
The Mute, 1, 8, 2, power may not work with your model I am not sure.
I do not expect the TV to come on when you hit '1'.
It should come on only after you enter the last button which is the power button.
BTW, the panel cannot cause that off color like that.
Old 04-29-2016, 11:46 AM   #11
Rickig
City & State: Kent
My Country: England
It's the original board fitted, tried 2 others. Tried a tcon tried a power board.
Old 04-29-2016, 11:46 AM   #12
dick_barton
My Country: Wales
Quote:
That's the code for my Samsung. Just checked.
Old 04-29-2016, 11:48 AM   #13
budm
budm's Avatar
My Country: USA
Quote:
Thanks for that info.
Old 04-29-2016, 11:18 PM   #14
Kilroys
City & State: southern part of Sweden
My Country: Sweden
Line Voltage: 230VAC 50Hz
Option codes
Kilroys is offline   Reply With Quote
Old 04-29-2016, 11:27 PM   #15
budm
budm's Avatar
My Country: USA
Thanks!
No LVDS codes for these series?
Old 04-29-2016, 11:32 PM   #16
Electronic Handyman
City & State: Ontario
My Country: Canada
In a lot of cases the Eprom has to be programmed for the board and that could be your issue.Some places sell the Eproms already programmed for the set you need it for.
Electronic Handyman is offline   Reply With Quote
Old 04-30-2016, 05:54 AM   #17
dick_barton
My Country: Wales
Have you still got your original main board and the original EEprom you could solder back in place?
Old 04-30-2016, 06:18 AM   #18
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Professional Tech
To get into the service menu press, from standby mode, Info Menu Mute Power
Only for European/Australian Samsung sets. US sets use Mute 1 8 2 Power.
__________________
Free service manuals: http://www.toms-service-manuals.com/ -- 72 LED/LCD TVs, 5 monitors, 28 plasma TVs, and 2 AVR 6.1 amplifiers fixed! -- I repair Pioneer 9G Plasma Main Boards & KRP-M01 Media Receivers (PM me for info)
2 Pioneer KURO 9G, 12 Panasonic LCD/Plasma, 1 Sony LCD, 1 NEC Plasma, 2 Yamaha HTS, 5 Sharp LCDs, 5 Toshiba LCDs, 7 Philips Plasma/LCD, 1 Hitachi Plasma, 11 LG LCD/Plasma, 18 Samsung LED/LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Grundig LCD, 1 Dell LCD, 1 iiyama LCD, 1 Acer LED, 1 Logik LCD, 1 Baird (China) LCD, 6 Bush LCDs, 22 Vestel LCDs (Best->Worst)
tom66 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
