Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 10-27-2013, 12:30 PM   #1
Dangermoose007
City & State: Lubbock, Texas
My Country: US
Line Voltage: 120VAC 60Hz
I'm a: Knowledge Seeker
Default Vizio VP50 HDTV10A
Bought this TV off CL with an issue powering up. The owner said it would take 2 or 3 times to get it started, and that progressively got worse. Once the TV got going it would work fine so long as it was left on, but if it was turned off, it would take a long time to get working again. The owner had some success putting a small space heater in the back, and managed to turn it on that way after warming it up, but it recently stopped powering up all together.
After looking up the model, saw that bad caps on the PS was a recurring theme. After taking it home and opening up, low and behold about 10 bad caps bulging, 2 with leakage on the PS.
Will be replacing caps, and let you know how it goes. Any other possible causes other than PS caps would be welcome of course, in case the cap replacement doesn't do the trick
Dangermoose007 is offline   Reply With Quote
Old 10-27-2013, 12:54 PM   #2
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Professional Tech
Default Re: Vizio VP50 HDTV10A
There are a few issues with AC detect on this model, but that's not too difficult to fix either.
__________________
Free service manuals: http://www.toms-service-manuals.com/ -- 72 LED/LCD TVs, 5 monitors, 28 plasma TVs, and 2 AVR 6.1 amplifiers fixed! -- I repair Pioneer 9G Plasma Main Boards & KRP-M01 Media Receivers (PM me for info)
2 Pioneer KURO 9G, 12 Panasonic LCD/Plasma, 1 Sony LCD, 1 NEC Plasma, 2 Yamaha HTS, 5 Sharp LCDs, 5 Toshiba LCDs, 7 Philips Plasma/LCD, 1 Hitachi Plasma, 11 LG LCD/Plasma, 18 Samsung LED/LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Grundig LCD, 1 Dell LCD, 1 iiyama LCD, 1 Acer LED, 1 Logik LCD, 1 Baird (China) LCD, 6 Bush LCDs, 22 Vestel LCDs (Best->Worst)
tom66 is offline   Reply With Quote
Old 11-09-2013, 06:41 PM   #3
Dangermoose007
My Country: US
Okay, I replaced the caps (Cherry popped!) and now the TV starts up almost instantly!
Which would be great if it wasn't for the red snow, and ghost like "reflection" of the No Input image. Now this may be caused by the panel being loose ( I may have undone more screws than required.) I see Ysus boards are likely culprit, but the owner indicated it wasn't having any issues except for the slow powerup before it stopped, and the PS cap replacement resolved that issue.
Any suggestions?
Old 11-09-2013, 07:17 PM   #4
Dangermoose007
My Country: US
...and then it stopped...
I went to take a picture of it to upload to this thread, and as soon as I lifted up the camera to take a picture, the red sparkles stopped. They appeared almost exclusively at the top half of the screen, and most concentrated at the top 8th of the screen, and must only last until the unit "warms up" (I'm fixing it in my garage, and it is November).
When I plug in the set, or turn it off, I do get 10 yellow/green alternating blinks on the front LED light, which I assume is an error code
it also had a burn in ghost image of the No Input box before when the the TV first started, before the No Input error popped up.
Old 11-09-2013, 07:48 PM   #5
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Maybe loose LVDS cable causing red snow.
As far as image burn in, you were probably observing image retention which has since faded, common with older LG plasmas.
Old 11-09-2013, 08:54 PM   #6
Glitcher
City & State: New York City
My Country: USa
I had this model with also the red sparkles on the top half of the screen. Turned out that some of the voltages were off spec (Vs, Va, etc) I readjusted them and the red sparkles were gone.
Glitcher is offline   Reply With Quote
Old 11-09-2013, 10:33 PM   #7
Dangermoose007
My Country: US
the burn in is now gone after watching a bit of TV. The red sparkles have yet to come back, but when there is a signal, there are areas of the TV that kind of flash and sparkle. I tried to take a picture, but my camera can't seem to pick it up, so i'll try to describe it;
1. The areas are about 9 pixels high and 27 pixels wide, so little rectangles.
2. their placement is static, so no matter what channel I'm on, they are on the same spot on the screen
3. they do not appear if the section of the TV they are on is a uniform color, so if the background of a commercial is all blue, you can't see them, but the portion of the commercial that has lettering or a product that touches some part of on of the trouble areas, the flashes appear.
4. they appear to alternate between white and black in 3 9x9 blocks within the overall 9x27 footprint.
5. They appear on black screens from an input (digital rabbit ears that have no tv channel selected but is powered on), but do not appear anywhere on the mostly black No Input screen.
Tom, I'll check the LVDS cable to make sure its nice and snug.
Glitcher, how do I adjust the voltages? Better yet, I have a multimeter, but how do I use it to TEST the voltages?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
